hydraulics and caraudio - Car Audio Classifieds!
Old 04-21-2016, 09:58 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Default hydraulics and caraudio
Have 3 batteries in series for 36v
Tried grounding 4th battery which is not connected to hydraulic batteries to trunk ground.
Front engine bay ground got red hot.
Upgraded to 1/0 in engine bay.
Rear 4awg ground got hot, smoking electrical tape, throwing mad sparks when touched to chassis ground in trunk.
What is going on?
Is it possible to have hydraulics and beat at the same time?
If so, how do you go about wiring an extra battery in the trunk for beat along with 3 batteries that are for hydraulics?
No, I'm not trying to hook up the 3 series batteries that are 36v to the 12v stereo system.
I'm guessing I need an isolator of some sort?
Also, it was working fine with an hc600 wired the same way, but we swapped out the hc600 for a big 850cca lead acid and that's when the problems started.
Oh and the series batteries were grounded to the chassis and I thought that was a bad idea.
Do hydraulic batteries need to be grounded to chassis? They are not being charged so I assume not, and that's why the wire is messing up.
team graham
Old 04-21-2016, 10:25 PM
0/11 sssss1070
your problem lies elsewhere, as long as the positives aren't in parallel or touching in any way to the stock system you'll be fine.
the grounds can all be on the chassis, without issues, according to the laws of physics.
Old 04-21-2016, 10:39 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
But if they were parallel then I could just wire them to the alternator and amp and what not, couldn't I?
Do I just connect the last ground in the set of batteries to the chassis ground? That's how it's connected now and it's not working.
Do you even need to chassis ground hydraulic systems?
Not gonna lie, the hydraulic wiring is a bit of a mess so I can't really say if it's correct or not...hard to say. I just know my car audio wiring is legit...gotta be something to do with the hydraulics
team graham
Old 04-21-2016, 10:40 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Early 4th of July huh lol
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 04-21-2016, 10:47 PM
0/11 sssss1070
hell to the **** NO!
do NOT connect a complete circuit with two different voltage systems in parallel. having them share a ground is one thing, having them share the entire circuit is a completely different thing
i dont know why you have a problem.
Old 04-21-2016, 10:58 PM
SPL Distribution Owner
0/11 sssss2983
IF you do not ground to frame, make sure you remember that you have a FLOATING Ground in your car. Do not ever allow anything including your body to touch anything coming from ground on that 36v bank to frame of car if you leave it like that.
Assuming batt 1 is power and batt 3 is ground, if you can't figure it out, need an ammeter to track down what is going on.
Old 04-21-2016, 11:52 PM
rocksolid84's Avatar
0/11 sssss1869
yes u can......
THE DARKNESS IS MY PEACE...
I ONLY BANG MIDGET STRIPPERS THEIR HALF PRICE
The Following 3 Users Say Thank You to rocksolid84 For This Useful Post:
colorblind83 (05-28-2016), graham (04-22-2016), Pioneer621 (05-28-2016)
Old 04-21-2016, 11:55 PM
0/11 sssss1869
you can parallel the last two batteries before the ground, the alt can charge the two in parallel.the one further down the chain is unefffected 24 volt 36 vole 48 etc....
the ground should attached to the rack via a quick disconnect then rack should be welded to frame..
The Following User Says Thank You to rocksolid84 For This Useful Post:
graham (04-22-2016)
Old 04-22-2016, 01:48 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Working on the same car pretty much lol.
I don't get it though.
We just want one extra battery for amps and 3 for hydros.
it's already grounded to the rack via the bolt holding all the batteries down.
I don't assume the first battery (for audio) being also in the same battery rack could be grounding itself that way?
I'll get to get some pics.
basically just 4 in a row, first one directly connected to front battery via welding 1/0 and grounded with 4awg 2' to trunk chassis.
next 3 up to 36v.
what would cause the arcing when grounding the first battery to trunk chassis?
team graham
Old 04-22-2016, 03:42 AM
Like mitchell said - you can share a ground plane amongst different voltages but the rest of either circuit must be isolated. It sounds like a wire somewhere in the 36v bank is grounded and creating a reverse polarity short to the 12v system. It would be like taking two batteries and connecting the positive of one to the negative of the other and vice-versa - you just get a big short.
new here from caraudio.com chargdbassbuick New Member Orientation 11 06-30-2012 10:56 AM
Ridiculous hydraulics? 98GCLimited Off Topic Chat 8 06-14-2012 04:49 PM
cce hydraulics mcintosh at asylum Craigslist Deals 1 01-23-2012 08:50 PM
Caraudio.com jt_buck Off Topic Chat 24 09-14-2010 07:33 PM
Caraudio.com KAPONE.SS General Car Audio Discussion & Questions 11 03-10-2010 09:38 PM
