Reliable and 3k+ for $500-600? - Car Audio Classifieds!
Old 04-22-2016, 07:33 AM
0/11 ssssss600
Default Reliable and 3k+ for $500-600?
I'm looking to replace my taramps dsp3k for something that will put out actual 3k+ at 2 ohms and has a great history. I knew I should have bought the 2 ohm model
I didn't want to spend more than $600 if possible.
Is this possible?
I don't play my system loud for more than a couple songs straight before i turn it up and down when i get to stop lights on my way to and from work and I have a 150a alt with about 100ah of batteries.
Old 04-22-2016, 07:35 AM
0/11 ssssss600
Right now I have a 74ah odyssey battery but I'll add another batt.
If I sell my taramps my budget will go up
Old 04-22-2016, 10:05 AM
mega fatty
0/11 sssss6008
What's wrong with the taramps?
Can you wire to .5ohm?
Sell that amp and get a 5k, that will put out around 3k at 2ohm, but if you wire to 2ohm your rise will make it less
Old 04-22-2016, 06:02 PM
0/11 ssssss600
Nothing is wrong with it. I just want more headroom and I have two d2 subs so I'm not getting full power.
Old 04-22-2016, 06:08 PM
mega fatty
0/11 sssss6008
Yeah should have gone with a 2ohm model
Or get a different 3k and wire to .5ohm
You will probably need a larger alt to safely run a 3k at .5ohm though
Old 04-22-2016, 06:44 PM
0/11 ssssss600
I didn't have these subs when I bought my amp and yeah I should have gotten d4 subs. Oh well.
I don't want to risk damaging this amp so that'swhy I'm here asking for advice on a stronger amp
Old 04-22-2016, 06:47 PM
0/11 sssss1070
if you can find a banda 7k..
The Following User Says Thank You to mitchell0715 For This Useful Post:
lalojamesliz (04-22-2016)
Old 04-22-2016, 06:49 PM
0/11 ssssss600
I don't see a available alternator for my car and I was trying to keep the weight down as much as possible that's why I didn't want to increase my battery ah capacity more.
This is why I need a strong amp
Old 04-22-2016, 06:54 PM
0/11 ssssss600
I'll look for one. Thanks
Old 04-22-2016, 06:57 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
it takes power to make power. try trading yours for a 2ohm version
Blazers reliable? JMoney18 General Automotive Chat 11 07-20-2012 02:08 PM
A reliable 4-8k amp. Silas Wanting to Buy (WTB) 10 02-26-2012 01:48 PM
Whats the most reliable sound_around General Car Audio Discussion & Questions 75 07-14-2010 04:36 PM
