grounding NEX4100 rca Q - Car Audio Classifieds!
Old 04-23-2016, 10:02 AM
West1's Avatar
0/11 ssssss231
Default grounding NEX4100 rca Q
I got static noise.
Pic is from Crutchfield.
Do I ground the pigtail rcas or do I open the HU and ground from inside the HU?
Thx for the help.
Purchased from- Melverc/SA Amp
Old 04-23-2016, 12:49 PM
0/11 ssssss600
Originally Posted by West1 View Post
I got static noise.
Attachment 80401
Thx for the help.
I recently had that same radio
I added a noise filter Crutchfield sent me that was like $20 and the engine noise/static went away
Old 04-23-2016, 12:51 PM
0/11 ssssss600
PAC SNI-1 Noise Isolator $7+ on amazon
Old 04-23-2016, 01:10 PM
West1's Avatar
0/11 ssssss231
Thanks, If worst case scenario I'll go that route. I'd like to fix the initial grounding issue and from reading I think this might be the way to go on Pioneer.
Old 04-23-2016, 01:55 PM
0/11 ssssss600
Np man, I wanted to open my radio up but then I wouldn't of been able to return it if I did.
Old 04-23-2016, 05:35 PM
West1's Avatar
0/11 ssssss231
Testing my ground per Youtube, am I doing this right?
Got my jumper cables out and connected the Neg. to battery Neg. to the back of the truck. With positive probe over ground screw, I got this number.
Multimeter set to 200 in Ohm section.
Seems to have a good ground for my mids and low.
I get no static noise from my Sub, only mids/highs.
Could it be rcas need to be ground?
Thanks for the help! I need this shit static gone
Old 04-23-2016, 06:28 PM
West1's Avatar
0/11 ssssss231
Seen my wires were close to the power so I popped hood, took out fuse for both amps, disconnected the speaker wires and moved wires around so they are not near power supply. Went to the hood and put fuses back in, fired up the truck and now my Mids/Highs don't turn on. Sub turns on but not amp for highs. Both 100amp fuses in the hood are good, checked amp fuses... they are good.
Damn I'm having a shit AUDIO day today, FML
Old 04-23-2016, 08:12 PM
Check voltage at the mid/highs amp. A poor ground or power connection or a loose connection somewhere in that circuit will cause noise and result in the amp not turning on. I had the same thing a few years ago - noisy amp that didn't work one day. Voltage was at 8-9v because of a loose fuse. Nothing looked abnormal or anything. Once I fixed that the amp turned on fine and the noise was gone.
Old 04-23-2016, 08:20 PM
Brand New Members
0/11 ssssssss1
I hope you get it resolved. I just purchased a 4200nex, an are scared to install it because of this issue. I know just the basics, so if I have this issue, I will not be able to trouble and resolve it.
Old 04-24-2016, 11:24 AM
West1's Avatar
0/11 ssssss231
I checked at the mids and im getting power. Ground looks good, it's tight and I never moved it.
Opened the amp and don't see anything burnt or anything smelling.
Im so lost at what it could be or what to do now, just bass sux ass.
10minutes later... Found the immediate issue, after cutting the tips of all wires, the remote wire was broken inside the set screw.
Buzzing is back, YES and **** all at once!
Grounding ??? HOYT4X General Car Audio Discussion & Questions 13 04-12-2014 08:11 PM
Grounding HU. Austin175 General Car Audio Discussion & Questions 5 06-07-2012 10:04 PM
grounding burd337 General Car Audio Discussion & Questions 13 07-07-2011 10:16 PM
grounding RCA"S massivespl General Car Audio Discussion & Questions 11 04-04-2011 03:33 PM
Grounding trunk hit hard like kimbo General Car Audio Discussion & Questions 16 02-13-2011 10:00 PM
