Triple Baffles - Car Audio Classifieds!
Old 04-25-2016, 06:48 AM
Red Light Ear Rapist
0/11 sssss1397
Default Triple Baffles
When is it really necessary to have a triple over a double? bpillar wall with 4 15s
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 04-25-2016, 07:06 AM
mega fatty
0/11 sssss6008
If you have to room why not
Especially in a wall you want the front and back wall as strong as possible
Old 04-25-2016, 07:19 AM
0/11 sssss1397
agree, just was debating it because id have to buy more wood, and even doubled its not flimsy but just makes me nervous
4 Crossfire v4 18s
Old 04-25-2016, 08:16 AM
Lock up your daughters!
0/11 sssss1342
For mine, I did a layer of 2x4's sideways on the inside so they're thickest. That was for strength. Then I did a sheet of birch plywood on the outside layer of the baffle for a cleaner look and good seal around the gaskets.
Then braced it front to back with a couple 1" threaded pipes, haha
My Silverado:
Old 04-25-2016, 09:02 AM
doug118's Avatar
0/11 sssss4674
Do like adulbrich did and throw a t right in the middle using 2 pieces of 2x4. That should be plenty and will only cost you a couple dollars. The only spot it could possibly flex is in the center and you sure as hell aren't flexing a 2x4 on end
Old 04-25-2016, 09:45 AM
massivespl's Avatar
0/11 sssss8409
I'd tripple and brace... It's amazing how much force 4 15s can create.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 04-25-2016, 10:23 AM
0/11 sssss1342
Yeah, more bracing the better
Baffle doesn't flex at all
My Silverado:
Old 04-25-2016, 11:26 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Then you're not lloud.
step it up son
team graham
Old 04-25-2016, 11:31 AM
0/11 sssss1070
He isnt that loud sooo
Old 04-25-2016, 11:35 AM
0/11 sssss1475
My baffle is 7 layers with a huge round over on the back side. Not sure if it helps anything but I have piece of mind knowing it's not flexing. After hearing bass in a concrete basement my eyes opened to the loss associated with flex. If it requires hundreds of pounds of force to bend a baffle, imagine the loss in output when a baffle flexes. I'd like to believe my bandwidth is due to the overkill wall I built.
99 s10 Blazer 2 door 5.7L Vortec swap
4- Team Ascendant Audio 18's
4- Ampere 8.0 TFE's
2- Zed Leviathan's
20 banks Maxwell caps
Team Ampere - Team Heavy Flex +160dB
fiberglass resin between baffles Gmanguy Enclosure Discussion & Design Construction Help 4 05-31-2014 12:21 AM
X T C 6.5" baffles oxsign Speaker Accessories & Parts 2 05-18-2013 03:43 PM
Cut Perfect Baffles! craiggus365 Tutorials & Quick References 0 10-07-2010 07:42 PM
Foam speaker baffles SPY Sound Quality Area 14 05-18-2010 10:38 PM
