3 dual 6.5ohm 2 single 3.5 ohm - Car Audio Classifieds!
Old 04-26-2016, 08:43 PM
0/11 ssssss132
Default 3 dual 6.5ohm 2 single 3.5 ohm
I have 3 dvc 6.5ohm mids and 2 single coil 3.5 ohm mids all are 8in amp to push them is a cadence zrs d1004 what would your set up with these be such as run 2 of the duals and 2 singles or just bridge the amp and only run the 3 dvc I'm open to any knowledge I can get here
Sent from my SM-G930T using Tapatalk
Old 04-26-2016, 09:05 PM
0/11 ssssss132
D100.4 - Cadence Sound
Old 04-26-2016, 09:06 PM
0/11 ssssss132
Link to amp specs if it helps
Old 04-26-2016, 09:14 PM
Run one DVC with coils wired in parallel to two of the channels. Run a SVC to each of the other two channels. Don't use the 5th speaker.
Old 04-26-2016, 09:16 PM
0/11 ssssss132
So are you saying only run 3 speakers
Old 04-26-2016, 09:57 PM
No; sorry I worded that strangely. Wire a single DVC speaker to two of the channels (so 2 DVC speakers) and a single SVC to the remaining two channels (2 SVC speakers). Four speakers will be used, one on each channel.
Also remember to wire both the DVC on one set of channels that share a gain control and the SVCs on the other set of channels that share a gain control, so you could do DVCs on channels 1&2 and SVCs on channels 3&4 for example.
Old 04-26-2016, 10:06 PM
0/11 ssssss132
Thanks for the info hopefully these will work well as a mid bass setup. All of these are generic version of the SAS bazooka 8in subs found in their tubes hopefully they stage nicely in my doors on the c1500
Old 04-26-2016, 10:43 PM
0/11 ssssss132
Old 04-26-2016, 10:44 PM
0/11 ssssss132
Old 04-26-2016, 10:47 PM
0/11 ssssss132
First three pics are dvc 6.5ohm 8in the other set are svc 3.5ohm how do I identify the manufacturer of these speakers
dual vs single port on dual sub box lalojamesliz General Car Audio Discussion & Questions 7 04-11-2016 09:54 AM
WTB Single dual 2-Ohm 15" Chris McNeeley Wanting to Buy (WTB) 7 04-20-2015 07:04 PM
dc audio lv2 8 m1 dual 1.5ohm loudmofo 8" Subwoofers 34 06-28-2012 06:51 PM
2 15'' L7 Kickers (dual 2 ohm) + Dual Vented Enclosure - Maryland/VA/DC Area 84Benzo Craigslist Deals 0 05-16-2012 05:38 PM
3 DD3510f dual 1.5ohm subs for sale recockulus1 10" Subwoofers 2 05-13-2012 03:28 PM
