Adding tweeter issue - Car Audio Classifieds!
Old 04-27-2016, 05:51 AM
0/11 sssssss86
Default Adding tweeter issue
Alright, currently I have ID 4x6 in the doors up front, and memphis 4x6 in the rear. I'm not switching them out for certain reasons...
I want to add a tweeter to my pillar to bring up the staging. I would prefer not to put in another amp. If need be I can though and run them active... but I'm hoping for an easier solution.
ideas I had....
1. Run off the deck, put passive crossovers in
2. Put in passive crossover from component set in, so both the coaxials and the tweets are powered off the amp
Just hoping for thoughts on the matter, or if either of my ideas are worth doing?
Here's the amps (just got them installed behind seat this week, finished tonight)
Old 04-27-2016, 03:35 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
If the speakers are the same impedance, run them on 2 channels.
If they are 4 ohm each, run 2 on 1 channel at 2 ohms and 2 on the other.
Use the other 2 channels for 2-4 tweeters or 8 if you get 8ohm.
If the current 4 channel isn't active, you'll have to add a crossover or in line filter anyway.
team graham
Old 04-27-2016, 04:19 PM
Souldrop's Avatar
0/11 sssss1270
Any reason you want rear fill?
2016 Scion iM
- Bone stock for now
Old 04-27-2016, 04:22 PM
Souldrop's Avatar
0/11 sssss1270
Any more details about equipment and what passive xover would you be using?
2016 Scion iM
Old 04-27-2016, 05:27 PM
Run them from the headunit because (a) you won't need very much power and (b) you'll be able to level match them with what you have already. Build some passives or use a spare set of component speaker passives on them.
d2freak82 (04-27-2016)
Old 04-27-2016, 05:48 PM
0/11 sssssss86
I have some inline filters for them if I was to run them off the deck. I also have the rca filters if need be. I would prefer not to run my fronts in mono, I could take them to 2 ohm, but I'm sure the tweets take a lot less juice.
I have several types of xovers for components.... an xtant set, several mpyre audio ones. I have all kinds of trinkets laying around lol.
Old 04-27-2016, 05:50 PM
0/11 sssssss86
I really like it?
Old 04-27-2016, 05:52 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Can't blame you. I know a few ladies who love a good filling in the rear if you know what I mean.
team graham
The Following User Says Thank You to graham For This Useful Post:
Mayhem (04-27-2016)
Old 04-27-2016, 05:54 PM
0/11 sssssss86
If you didn't already see, the cross overs are from xtant and mpyre audio.
I'm running an Audiopipe APMI-2000 and memphis 4x50
My sub is an old school orion HCCA 15
Old 04-27-2016, 06:01 PM
So Low's Avatar
0/11 sssss1258
You can use a passive crossover along with the coaxial as long as you wire the tweeters in parallel to the coaxial. Series connection would conflict with the existing crossover points as well as the tweeter crossover.
Don't be worried about wiring too low, just crossover the tweeter very high with a high quality capacitor and the ohm load won't change much at all.
The Following User Says Thank You to So Low For This Useful Post:
Weird tweeter issue Bilz12 General Car Audio Discussion & Questions 4 09-08-2013 02:41 PM
aq pa tweeter issue fyerbyrd22 Sound Quality Area 2 08-29-2013 08:40 PM
Pioneer DEH-880PRS w/ pico fuse issue and flex ribbon issue groundpound4200 Broken & Non-working equipment 3 04-15-2013 06:58 AM
Adding another battery tyler.frost92 General Car Audio Discussion & Questions 10 09-25-2012 02:24 PM
Adding another alternator - NEED HELP Vital General Car Audio Discussion & Questions 24 01-03-2011 02:06 PM
