how low is too low - Car Audio Classifieds!
Old 04-27-2016, 12:04 PM
CHRISGIBSON333's Avatar
0/11 ssssss332
Default how low is too low
I have got some voltage drop going on waiting for my alternator. It is dropping to 11.6. Will this damage the amp if I run like this for a week or 2? It is a dc 10k I have 500ah battery bank. thanks
Old 04-27-2016, 12:10 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
If you're wired to 1ohm or better I think you would be OK but if you are wired below 1ohm I would keep it 12v and higher, that's a expensive amp just turn the gain down until you get your alt
The Following User Says Thank You to B-Shot For This Useful Post:
CHRISGIBSON333 (04-27-2016)
Old 04-27-2016, 12:32 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
I would keep any amp above 12.6v at all times
team graham
Old 04-27-2016, 12:34 PM
0/11 sssss1070
depends on the amp... pretty sure dc10ks are made for power up high.
i wouldnt clip it that low, other than that i think you'll be fine
Old 04-27-2016, 12:50 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
I guess its me but, I just couldn't let my amp see under 12v...
Sent From My Phone
Old 04-27-2016, 12:55 PM
mega fatty
0/11 sssss6008
With an expensive amp like that I would hold off a bit especially if the alt is on its way
With my $99 vvme amp it saw 10v's at .5ohm all the time and would protect daily, but it kept on keeping on.
Old 04-27-2016, 12:56 PM
0/11 ssssss332
It is the 12 volt version
Old 04-27-2016, 01:03 PM
0/11 sssss1070
id imagine you're fine then. i wouldnt hard clip it or let it eat up low 11s all day long but it'll be fine imo
Old 04-27-2016, 06:53 PM
Lock up your daughters!
0/11 sssss1342
I wouldn't chance that with a DC 10k!
I don't let my 7k's dip anywhere close to that low
My Silverado:
Old 04-27-2016, 07:12 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
I would ease up on it in case something does fail between now and until you get your alt. But that's me, and you just never know.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
wtb: 6.5 inch coaxials or components por el low low rachidfunaki Wanting to Buy (WTB) 4 02-16-2015 01:02 PM
Big Motored Subs? Do I still need to tune low to play low? jfoodstamp General Car Audio Discussion & Questions 14 10-14-2012 08:00 PM
BNIB Treo rsx 1900. for the LOW LOW snoopysnooper Mono Amplifiers 8 05-04-2010 03:53 PM
[TRADED] 8" resonant engineering re8 on the low low snoopysnooper 8" Subwoofers 17 12-14-2009 01:31 PM
Low coolant warning light - Its not low tho..??? westman995 General Automotive Chat 9 11-24-2009 08:45 PM
