2004 tahoe hatch glass rattling like a mother f@cker - Car Audio Classifieds!
Old 04-28-2016, 10:15 AM
CHRISGIBSON333's Avatar
0/11 ssssss332
Default 2004 tahoe hatch glass rattling like a mother [email protected]
So I just got my set up going and rear glass is rattling like a mother. I know there are a bunch of hoes on here any tricks to get it quite. Thanks for the help
Old 04-28-2016, 10:29 AM
massivespl's Avatar
0/11 sssss8409
Open window. Put a big bead of windshield adhesive on the seal and close the window... Then on the inside of the window while its closed run another bead around the window... That's what I did with my Tahoe.. And I put a big glob right on the latch itself because the latch was about to break.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
The Following User Says Thank You to massivespl For This Useful Post:
CHRISGIBSON333 (04-28-2016)
Old 04-28-2016, 10:37 AM
0/11 ssssss150
So does that mean your hatch window is sealed for good?
Old 04-28-2016, 10:54 AM
0/11 sssss1070
yes, you can peel it off later but it'll take a good amount of effort
Old 04-28-2016, 12:12 PM
massivespl's Avatar
0/11 sssss8409
Yea but the bass loosened the window back up after time but still alottt better.... Let me go take some pics of my latch because this is what worked the best for me.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 04-28-2016, 12:29 PM
massivespl's Avatar
0/11 sssss8409
Soon your latch will look like this^ depending on what type of window you have matters because my 2002 rear hatch glass the latch is one price connected to the window. So if the latch breaks you have to get a whole new window... Some other year tahoes you can just replace the latch.
I just put big glob of adhesive on the latch and no problems lol
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 04-28-2016, 01:56 PM
0/11 ssssss332
right on thanks for the info. Is you back glass deadened or painted?
2004 Tahoe
2 team fi 18
dc 10k
4 rf 6.5 pro
ppi ion 1000.4
dc power 300amp alt
500ah group 8 battery
Old 05-01-2016, 04:52 PM
The_Dealer's Avatar
0/11 ssssss212
I used the thick rubber gasket stuff(window a/c unit seal) from Lowes and stuck it onto the back glass so it would sit up against the factory seal. After I adjusted the latch a little 90% of the rattling was gone.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 05-01-2016, 05:20 PM
Mayhem's Avatar
0/11 ssssss175
I lined the window with weather stripping sealer.
Did two layers of the thick then a smaller line in the middle of those.
Didn't make a sound after that.
Also, if you do this you can open close the hatch all you want because it expands when it opens then seals up when shut.
I fart at 30hz
Old 05-01-2016, 05:27 PM
massivespl's Avatar
0/11 sssss8409
Screw not making noise... Your losing pressure out the glass... Seal that shlt up tight like my pictures. I gained like 1db sealed my hatch window and those vent caps in the back
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Back Hatch glass... IowaBass General Car Audio Discussion & Questions 7 10-05-2014 12:35 AM
rear hatch rattling Stonepatterson General Car Audio Discussion & Questions 19 06-06-2014 01:04 PM
Hatch glass rattle Alek17 General Car Audio Discussion & Questions 20 06-18-2013 12:07 AM
tahoe glass ftl DC98hoe (DC) 33 08-29-2011 11:33 PM
Zach's 2004 Focus hatch stangman67 Team NWSPL 99 04-13-2011 05:11 PM
