Dc power alternator question - Car Audio Classifieds!
Old 05-05-2016, 12:27 PM
0/11 sssssss31
Default Dc power alternator question
I currently have a dc power 320spxi that is on a dual bracket and is self regulated. it has the relay that dc provided so that it doesn't have issue with my 07 avalanche' pcm. So my question is, is there any way to up the charging voltage? I've heard that there is some trick with a diode and fuse you can do but don't know the specifics or if it really works. Any and all help is much appreciated.
Old 05-05-2016, 03:34 PM
Putting a diode on the alternator's "sense" wire will drop the forward voltage by about 0.7v. The regulator then thinks the car's voltage is too low and raises it. The fuse thing is just a special holder that uses a diode encased in a fuse form factor to make it easier to wire in. Google "ATC diode" or something like that for examples.
Old 05-05-2016, 03:37 PM
0/11 sssssss31
So technically wouldn't a resistor do the same thing?
Old 05-05-2016, 03:48 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
no
alternator question nmachado99 General Car Audio Discussion & Questions 11 11-08-2014 10:18 AM
FS:DC Power 270sp Alternator and VCM XS Power Module*Both In Mint Condition* deepsilencer Car Audio Packages 12 03-22-2013 11:48 PM
H/O alternator question Aldundra General Car Audio Discussion & Questions 2 08-22-2010 08:29 AM
Alternator question denali804 General Car Audio Discussion & Questions 3 08-21-2010 03:27 PM
alternator question? Dunbar91 General Car Audio Discussion & Questions 5 08-13-2010 09:13 PM
