Maxwell 16V Module - Car Audio Classifieds!
Old 05-06-2016, 11:59 AM
0/11 sssss1122
Feedback Score: 23 reviews
Default Maxwell 16V Module
Has anybody used these? Looks like they would be an easy integration. Any reason why it could not be used in a vehicle running 12V?
BMOD0500 P016 B01 Maxwell Technologies | Mouser
Old 05-06-2016, 01:44 PM
Those will work with 12v systems. Maximum voltage is listed at 17v. They are over $550 dollars though, which is a couple hundred bucks more than buying the caps themselves and doing the fab work to hook them all up.
Old 05-06-2016, 05:18 PM
0/11 sssss1122
I'm not to concerned about the price difference. What attracts me to the module is that the caps are enclosed and out of harms way. The screw in terminals will be easy to use as well.
Old 05-06-2016, 05:36 PM
0/11 sssss1122
I also came across the Maxwell Ultra31/1800 12-Volt Heavy-Duty Engine Starting Module. They are not cheap at ~$1000, the yhave (12) 3000F capacitors in them, pretty cool.
RV Cams Maxwell Ultra31/1800 12-Volt Heavy-Duty Engine Starting Module
Old 05-06-2016, 05:46 PM
Lock up your daughters!
0/11 sssss1342
That engine starting module is sweet!
My Silverado:
Old 05-06-2016, 07:13 PM
HiloDB1's Avatar
0/11 sssss3158
This also has built in balancing with active voltage monitoring basically a BMS system built in.
Old 05-06-2016, 07:24 PM
0/11 sssss1122
Exactly. I will not need to use the electrical plug in the middle right?
Old 05-06-2016, 07:28 PM
HiloDB1's Avatar
0/11 sssss3158
The plug is for the monitoring system. You dont need it but not using it defeats the point of buying that particular system.
Old 05-06-2016, 08:03 PM
0/11 sssss1122
My interest in this module is that the caps are enclosed, balancing circuits are included and ease of integration in my charging system. I am not aware of a 16th 500f module that doesn't have a built-in temperature monitor.
Old 05-06-2016, 10:35 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
The engine start won't work well I don't think as it charges differently than it powers. You *MAY* be able to just connect to the "starter" post and charge it that way but I'm not sure you should.
Current Build:
#60sHereIcome
Tags
maxwell module
(15) 16v batteries and a 16v battery charger for sale devin20852 Wiring, Electrical & Other Installation Equipment 6 10-16-2015 07:59 AM
ILS Module (Maxwell 2600 Caps) bumpin buick Wiring, Electrical & Other Installation Equipment 10 03-02-2014 11:01 PM
wtb: batcap 16v 8400 or 16v bat bank it lbs Wiring, Electrical & Other Installation Equipment 2 07-05-2013 11:35 AM
What special module do you need to do a 16V system? mattintc10 General Car Audio Discussion & Questions 10 09-28-2010 09:44 AM
Bat Cap 8400 16v or cactus batts 16v Team Car Tunes Jeff Wanting to Buy (WTB) 0 06-29-2010 09:53 AM
