Best 16v amp options? - Car Audio Classifieds!
Old 05-08-2016, 04:54 PM
doug118's Avatar
0/11 sssss4674
Default Best 16v amp options?
Need around 10k clamped @ 18v. Right now I'm torn between a pair of the older sundown saz3500's and Soundqubed 3500's. A single large amp is also an option but I'm not looking to spend more than $1k total for amp(s)
Old 05-08-2016, 05:26 PM
0/11 sssss3526
Those amps you are looking at are probably your best option
Old 05-08-2016, 06:03 PM
doug118's Avatar
0/11 sssss4674
That's what I figured. Now I just need to figure out what the bare minimum I can get away with for electrical
I can't find real world clamped numbers for either amp at 18v. I'm going to assume they're both in the 6k range
Old 05-08-2016, 06:39 PM
massivespl's Avatar
0/11 sssss8409
What are you going to wire to? Getting 10k clamped outta those amps your going to have to wire .5ohm strapped and have low rise.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 05-08-2016, 07:14 PM
doug118's Avatar
0/11 sssss4674
Probably .5 each
Old 05-08-2016, 07:26 PM
0/11 sssssss50
Do you already have 16v batts
Old 05-08-2016, 07:30 PM
doug118's Avatar
0/11 sssss4674
Nope this is for a completely new build I just started on
Old 05-08-2016, 09:06 PM
Uzi4life991's Avatar
0/11 sssssss36
twisted sounds 3.5ks are 18v stable and are way under rated. pretty sturdy amps wired low!
Old 05-08-2016, 09:36 PM
doug118's Avatar
0/11 sssss4674
they're a little too rich for my blood. my front stage is costing me about $5k so I'm trying to get the best bang for the buck with the substage. I've had really good luck with older sundown amps and audioque stuff
Old 05-08-2016, 09:46 PM
0/11 sssssss50
What's ur thoghts on 16v lithium can get smaller packs now
wtb: batcap 16v 8400 or 16v bat bank it lbs Wiring, Electrical & Other Installation Equipment 2 07-05-2013 11:35 AM
Go 16v or stay 12v? Options listed doug118 General Car Audio Discussion & Questions 55 11-15-2012 10:49 PM
any 16v mids&highs amp? toad559 General Car Audio Discussion & Questions 4 01-03-2012 02:12 PM
Bat Cap 8400 16v or cactus batts 16v Team Car Tunes Jeff Wanting to Buy (WTB) 0 06-29-2010 09:53 AM
Going 16v and need some advice, options Andrew2944r General Car Audio Discussion & Questions 30 12-08-2009 01:50 PM
