Alternator or battery question - Car Audio Classifieds!
Old 05-18-2017, 08:00 PM
0/11 ssssss153
Default Alternator or battery question
My voltage meter-at amplifiers- never gets below 12.5 at full tilt with lights on.Ok so my
lights will dim very very little.Bigger alt or bigger batt/more batts?The battery never seems even alittle drained on resting voltage-12.4 or higher even after hours of hard play.Whats the cause?
Yes big 3 is up to par.
Yocom
Old 05-18-2017, 08:42 PM
Mayhem's Avatar
1/11 ssssss148
What is the current Alt/battery setup?
Regardless I would get an alt.
I fart at 30hz
The Following User Says Thank You to Mayhem For This Useful Post:
SUPER_YOCOM (05-18-2017)
Old 05-18-2017, 09:17 PM
0/11 ssssss153
Thanks Mayhem
Battery Xs 3400, alt is 125 amps and pickup is a 84 nissan 720 that only needs 30 amps to run with lights and heater.The problem is very small.Just wanted opinions.
Yocom
Old 05-18-2017, 09:20 PM
jigsizzle's Avatar
Jet Life
1/11 sssss2022
I would get the alt, you'll have power for future upgrades...
Sent from my SAMSUNG-SM-G530AZ using Tapatalk
The Following User Says Thank You to jigsizzle For This Useful Post:
Old 05-19-2017, 06:37 AM
0/11 sssssss19
Yeah I would say the answer to this question is always alt but even then your lights may not stop dimming. Even .1 drop can cause older lights to dim. The severity of the dim may lighten up tremendously though.
0/11 sssssss19
Hell you may want to look into a light upgrade.
Old 05-19-2017, 06:49 AM
2/11 ssssss157
yes the Alternator is a great choice, but another question might be is how do you like to play your system. Low to medium volume then once in a while you turn it up to show someone what it does. Or do you play at just about full tilt and use your lights as a guage. As in turn it up till the lights just start to dim. Adding both ALT and Batteries might be the best choice.
Old 05-19-2017, 11:49 AM
Mayhem's Avatar
1/11 ssssss148
Tradition headlights will dim but HIDs won't? Or it won't be as noticeable as traditional lights. I think....
I want to say that is correct but I could be totally wrong.
If light dimming is an issue you want to resolve then that could be the solution. *if I'm right*
I fart at 30hz
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Another battery or HO alternator? Dammed General Car Audio Discussion & Questions 23 12-08-2012 04:54 AM
battery or alternator biglion General Car Audio Discussion & Questions 45 09-07-2012 07:35 PM
Alternator/Battery help bottlefed1 General Car Audio Discussion & Questions 12 02-19-2011 05:03 PM
Alternator or another battery? jcp0420 General Car Audio Discussion & Questions 11 03-23-2010 01:17 AM
battery and alternator????????????? fyerbyrd22 New Member Orientation 2 10-05-2009 08:23 AM
car audio forum, moble audio, car stereo, wholesale car audio, 12 volt, with, amplifier, amp, subwoofer, sound quality, buy car audio, and sell automotive stereo systems for cars Plum is my hero!
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
