Honda Civic premium amp bypass - Car Audio Classifieds!
Old 07-07-2017, 05:33 PM
0/11 sssssss91
Default Honda Civic premium amp bypass
In the middle of upgrading the system in my 2015 honda civic and thought I should share the fact you can by pass the amp without cutting anything by using JAE connector MX34014NFA it will allow you to hook up directly to the premium heads output and tap into the signal before the amp. The plan is to run this into a pair of minidsp balanced 2x4 and output the signal unbalanced. I'll follow up when those arrive.
Old 07-22-2017, 02:43 PM
0/11 sssssss91
so this is the guy that seems to cause everyone issues. The interesting bit is compared to every pin-out I have seen online there is no shield wires. However, the aformetioned connector I picked up allows a person to connect direct to the Premium heads outputs with out cutting anything.
The outputs are being fed into a single minidsp 2x4 balanced for now and seem to have zero noise so far. However, the real test will be when I hook to the Stevens HLCD.
should be an intresting setup
Full body HLCD
MB8-2's
still on the fence on subs but probably sp4's for now
Old 08-09-2017, 10:33 PM
0/11 sssssss91
Well the minidsp seems to work reliably to create a clean signal so its time to add some toys.
190 amp singer alt for honda civic 05-11 travis420 Wiring, Electrical & Other Installation Equipment 1 06-05-2013 09:58 AM
need help on a few things dc alt honda civic eld bypass? Guerra213 General Car Audio Discussion & Questions 11 01-29-2012 09:41 AM
my '98 honda civic EX Nik592 Member Rides & System Pictures 26 07-09-2011 09:34 PM
Does anyone have a Honda civic or civic/si 2006-2010 or Audio_Prodigy General Car Audio Discussion & Questions 1 09-17-2010 11:37 AM
