frontstage upgrade - Car Audio Classifieds!
Old 08-01-2017, 11:32 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
Default frontstage upgrade
I have vifa 50w tweets and either pdx 6.5 or soundstream PA mids.
They aren't loud enough anymore.
power I have is a s800/4 or ppi 900.4
80-100w vifa silk domes and 6mr500's?
team graham
Old 08-01-2017, 12:29 PM
Tymphany makes a couple horn-loaded tweets that might give you a bit more output without making the jump to bullets/supertweets. These should at least sound better and not require too much EQ like something more efficient would.
https://www.parts-express.com/peerle...ter--264-1028?
https://www.parts-express.com/peerle...-ohm--264-1390
There might be more in that line, I'm not sure.
graham (08-01-2017)
Old 08-01-2017, 04:11 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
I have the ones in the first link lol.
would the second link be noticeably better?
team graham
Old 08-01-2017, 04:35 PM
Well then, lol. Honestly I haven't heard either one but I doubt they will be much different. The second ones don't appear to be as sensitive so that's not the direction you want to go if you already need more than the first ones give you.
graham (08-01-2017)
Old 08-01-2017, 04:40 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
Well mine are 50w...other are 100w...I'm assuming that should be quite louder?
team graham
Old 08-01-2017, 09:04 PM
I misread what you said earlier and thought you already the the ones in the second link (the $20 ones). Those will be a couple dB louder and might be worth a shot.
I bet the voice coil on both of those is exactly the same. The second one ($20 one) is more sensitive because it has 2/3 the moving mass and a slightly stronger motor structure. Point being - neither one is going to take 100w. I don't know why the rated power handing is so much different.
graham (08-01-2017)
Old 08-01-2017, 09:13 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
I have them on the s800/4 now. Very little gain though. 4v unit, USB with decaf.
they have lasted a while. But I always listen for distortion.
I was leaning towards these
https://www.parts-express.com/peerle...eter--264-1006
https://www.parts-express.com/peerle...eter--264-1034
team graham
Old 08-02-2017, 02:13 AM
If you want louder neither of those would do any good. The one's you have now are close to the upper limit of efficiency with a conventional dome tweeter. I'm sure you could find something with a larger coil and better cooling to get a little more power to them, but you start trading efficiency for power handling and it comes out a wash.
graham (08-02-2017)
Frontstage help. j4tk1 General Car Audio Discussion & Questions 43 01-23-2016 07:14 PM
i need a help/opinions for my frontstage NvrDoneD50 General Car Audio Discussion & Questions 8 12-27-2011 01:02 AM
great frontstage? STRATUSBEATZ General Car Audio Discussion & Questions 8 05-20-2011 03:28 PM
Frontstage power? C3 Customs General Car Audio Discussion & Questions 0 03-02-2011 08:39 AM
new frontstage RidnClean General Car Audio Discussion & Questions 7 06-11-2010 03:33 AM
