system questions - Car Audio Classifieds!
Old 10-19-2017, 01:34 PM
0/11 ssssssss6
Question system questions
hello all, i have a sundown audio saz 4500 and two zv3 18's dual 2ohm wired at 2ohm till my electrical is right. Anyway i have a 250amp alt 180amp at idle, a small agm (55ah) under the hood, dual runs of 2/0 ofc. sundown says the amp runs 2000rms at 2ohm loads which if I'm correct should be around 200amps draw. Just had the alt load tested and is working great. Battery is new. Yet my voltage drops SIGNIFICANTLY when the bass hits. Any ideas? is the sundown actually throwing more power and drawing more amps? My first sundown setup so i don't know a lot about them
thanks in advance
et my voltage drops SIGNIFICANTLY and immediatly when the bass hits. Just had the alt load tested for output and is working properly.
Old 10-19-2017, 01:54 PM
0/11 sssss1117
You're probably drawing more amperage then you think. And if you don't have a reserve it's not gonna help with voltage drop. And alt works on loads so it might not be quick enough to output full amperage at idle or higher rpm. So I'd imagine you drop instantly to 12.6v then below for longer bass notes. Try backing off the gain to help until you get more battery reserve and I'd recommend lithium battery as they will charge up to alternator voltage and works it way down while playing and idling with the alt. And unlike battery lithium battery and ultracaps will put a load on the alt til it's charged up to alt voltage which is nice cause you will have a continuous load on the alt which some say is bad. Maybe in the long run but did so for 3yr and no issue
The Following User Says Thank You to SPL Addict For This Useful Post:
quadthrees (10-19-2017)
Questions on system raw-lightning General Car Audio Discussion & Questions 1 04-01-2013 11:49 PM
New system questions Bradleyj0808 General Car Audio Discussion & Questions 1 01-31-2011 01:08 PM
Some questions on tuning my system 87linkin General Car Audio Discussion & Questions 12 07-12-2010 02:53 PM
system questions mjw91 General Car Audio Discussion & Questions 0 05-30-2010 07:17 PM
system questions fyerbyrd22 General Car Audio Discussion & Questions 21 03-25-2010 06:59 PM
