Coil question.... - Car Audio Classifieds!
Old 12-17-2017, 08:14 PM
0/11 ssssss118
Default Coil question....
There is a guy here in my town that says its fine to run 1 coil of a dual coil sub . Is this true? Example running 2 dual 2s and getting a 1 ohm load by only using 1 coil of each sub
Old 12-17-2017, 10:43 PM
mega fatty
0/11 sssss6008
It's "fine" the rms is in 1/2 or maybe even less
Just run both coils at 2 ohm total or .5 ohm if you can
Old 12-18-2017, 01:22 AM
0/11 ssssss118
So the sub will only handle have half the rated power with running only 1 side of it?
Old 12-18-2017, 10:32 AM
mega fatty
0/11 sssss6008
Yes probably a little less than 1/2
Just run it at 2 ohm or .5 ohm if your amp can handle .5
Old 12-20-2017, 08:24 AM
0/11 ssssss543
Running only one side will also effect t/s parameters and require a new box of box is designed for factory parameters.
Old 12-23-2017, 10:56 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
Yeah nah use both coils.
team graham
coil question audioangel General Car Audio Discussion & Questions 3 01-08-2012 03:56 AM
Spl coil vs stock coil question (for sa series) newarkbeast973 (Sundown Audio) 2 11-17-2011 01:09 AM
E8v2 Coil Question jagblazer01 (Sundown Audio) 2 03-29-2011 09:43 PM
coil question augustijnen peter General Car Audio Discussion & Questions 22 05-21-2010 05:55 PM
voice coil question davidrforbus General Car Audio Discussion & Questions 6 03-02-2010 08:17 AM
