2012 Focus Factory Sony Head Unit Amp Install Help Needed - Car Audio Classifieds!
Old 12-29-2017, 05:56 AM
only126db's Avatar
The One U Love 2 Hate
0/11 sssss2943
Default 2012 Focus Factory Sony Head Unit Amp Install Help Needed
I am looking at purchasing a fuel efficient ride and was looking at an 'F' word, but of course I have to modify the sound system so I am looking around for info.
This 'F' word I am looking at has the factory Sony head unit which is Nav capable (with some software programming I gather), I believe it is Sync2 with Ford Mytouch. I cant find any good info on amplifier upgrade capabilities besides with the lower level factory units so I was wondering if anyone here has any experience with these vehicles/systems....
What is needed? Is there a module, will I need to go full out and wire my own harness, any info is appreciated....
Thx
Old 12-29-2017, 09:10 PM
jeffdachef's Avatar
0/11 ssssss440
Look up rockford DSR-1 and see if its compatible with your focus. You can just use a T harness, flash the dsp to the vehicle model and viola 8 channels of rca output, time alignment, active networks 31 band eq, the works. All bluetooth tuned on your phone as well.
Old 12-30-2017, 01:40 AM
only126db's Avatar
0/11 sssss2943
A little more than what I would need feature wise, any other options?
Old 12-30-2017, 08:31 AM
ludeman's Avatar
0/11 ssssss467
iDatalink - Maestro - Home Give them a shot!
Ray
Old 12-30-2017, 10:06 AM
only126db's Avatar
0/11 sssss2943
Looking like I am gonna pass on the little car, doing research has brought me to a dead end...There is some issue with how the factory alt. Is made so there are no h.o. units available for it and since it has a factory sony unit It is likely going to cost too much to upgrade to just have ok sounds....cant live with it that way... Ford n Sony = poop
Old 12-30-2017, 10:36 AM
ludeman's Avatar
0/11 ssssss467
Completely understand! I was set on the Explorer, then ended up getting a Grand Cherokee. Cause of the Sync & alternator location.
Ray
Old 12-30-2017, 02:33 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Any ideas on the next vehicle?....
Sent from my SamsungLife using Tapatalk
Hook system up with factory head unit mcummings2 General Car Audio Discussion & Questions 11 08-15-2014 07:04 PM
Factory head unit to RCA convertor fosgatefeind Wanting to Buy (WTB) 3 01-20-2013 11:15 PM
sony mex-bt5000 highend sony head unit 4v preout usampsman Head Units, Processors & EQs 9 05-01-2012 11:42 AM
Aftermarket head unit/nav install & how to on gm trucks panda Tutorials & Quick References 0 04-13-2012 09:36 PM
Factory Head Unit cause clipping? NathanLewis General Car Audio Discussion & Questions 9 03-03-2010 01:46 PM
