help me design a box for 2 ssa xcon 10 inches for daily - Car Audio Classifieds!
Old 01-03-2018, 01:27 PM
0/11 ssssssss7
Default help me design a box for 2 ssa xcon 10 inches for daily
Hello guys
Can you help to design a box for my subs, here is the info about what I want
Subs : 2 (ssa xcon dual 2) 10 inches( 2017 model). Here is the ts parameters
·******** FS: 37.9
·******** QES: .38
·******** QMS: 5.3
·******** QTS: .35*
·******** SD: 310
·******** VAS: 8.4L
·******** SPL: 82.7
·******** BL: 15.74/22.25
·******** RE: .7 ohm / 1.4 ohm*
·******** MMS: 279
·******** Xmax: 29mm
·******** RMS: 2000W
Sub amp : 2 zapco st-2000xmii strapped at 2 ohm
Car : yaris 2010 sedan
Box location : in the trunk with sub and port pointed toward the cabin because I wanna sealed the box off
Space available : I will have a weird shaped box because I have to have access to batteries the net available space inside the box is 5.8 cube.
Rear seat: I have 3 rear seats. I can fold one seat behind the driver seat or I can fold the middle and the one behind the passenger together because they are attached and of course I can fold them all *
Electrical : 1 singer alt 320 amp with 3 acid batt of 250 amp combined
Bandwidth needed : from 25hz to 50 Hz minimum. The wider the better especially on the lower side but if it will comes at the cost of achieving the goals over the needed bandwidth then I don’t want it
Goal : daily system with clear clean accurate sounding bass, extremely loud across the bandwidth while murdering the hell out of the lows especially 32 hz and below
Type of music : I listen to every type of music. Rock, jazz, pop you name it and I listen to a lot of slowed music . decaf djsnt and such
Proposed box : based on ssa recommendation and my little knowledge and the space available I thought *3.5 cube tuned to 31 with 60 inch squared of port area or 3.5 cube tuned to 28 with 52 inch squared.
I have graphed the tow boxes in Bassbox6 pro. The yellow graph is 32hz box, the orange is 28hz. here is the result
https://imgur.com/a/qMMou
This is the typical response and as you can see the 28hz box have an advantage over the other box from 30hz and below which is really what I want.
But
Here is the response when I apply the port resonance
https://imgur.com/CETIEWv
As you can see the 31hzbox is louder from around 27hz and up over the other box . which if it was true I will do it
My questions : is my tow proposed designs are going to help me achieve my goals and if so which one of them
Is the port resonance predicted by the program true
Where should I place the port ( behind driver seat or passenger seat or in the middle ) the port is slot
If my proposed designs are wrong what is your recommendation based on everything I mentioned
Any help is appreciated and if there is anything you want me to add please tell me
I hope I covered everything needed and thanks in advance ***
Old 01-05-2018, 04:23 AM
0/11 ssssssss7
@hackmunch i would like to know your input
Old 01-05-2018, 05:14 AM
0/11 ssssssss7
[MENTION]TaylorFade[/MENTION ]
[MENTION]massivespl[/MENTION ]
Old 01-05-2018, 05:15 AM
0/11 ssssssss7
@massivespl
@TaylorFade
I would like to know your input guys
Old 01-06-2018, 08:39 AM
0/11 ssssssss7
Anyone?
Old 01-07-2018, 10:44 AM
0/11 ssssssss7
No one?
SSA XCON 15 dual 2 or just a XCON motor dwpjr Wanting to Buy (WTB) 0 08-16-2013 07:58 PM
SSA Xcon 15 fireitup 15" Subwoofers 7 04-28-2013 02:44 PM
In need of box design for SSA Icon ENVI3D ONE Enclosure Discussion & Design Construction Help 3 03-17-2013 12:37 AM
WTB: SSA Xcon 12 d2 or xcon motor Bushj311 Wanting to Buy (WTB) 9 01-21-2013 03:38 PM
Fs: Ssa xcon d1 my_stealth21 12" Subwoofers 8 08-10-2011 08:00 PM
