External voltage regulator - Car Audio Classifieds!
Old 01-19-2018, 09:06 AM
oxsign's Avatar
0/11 sssss1876
Default External voltage regulator
Looking at getting an external voltage regulator for my Mechman. Reading on their site it states “THIS PRODUCT IS ONLY INTENDED FOR VEHICLES THAT USE AN EXTERNAL VOLTAGE REGULATOR FROM THE FACTORY.” Is this a problem to use otherwise?? It’ll be used on my 2010 Avalanche as a second alt.
1971 VW Fastback
Old 01-19-2018, 10:37 AM
doug118's Avatar
0/11 sssss4674
Is it the alt designed for that truck?
Old 01-19-2018, 12:00 PM
oxsign's Avatar
0/11 sssss1876
It is. Bought it specifically for it 2 yrs ago. However, I did just send it back to have it changed over to a single wire connect to use as a secondary alt to the factory 160 amp. So I was wanting to put a regulator on it to adjust it separately.
External voltage regulator on PCM controller voltage BassCruze General Car Audio Discussion & Questions 14 10-31-2014 07:02 PM
blue box external voltage regulator jaredspl Wiring, Electrical & Other Installation Equipment 10 09-21-2012 04:06 AM
External voltage regulator Audioatg Wiring, Electrical & Other Installation Equipment 3 11-18-2010 07:41 AM
external voltage regulator help Slam General Car Audio Discussion & Questions 1 10-23-2008 10:46 AM
