Feed back whine from components at low vo - Car Audio Classifieds!
Old 01-27-2018, 06:44 PM
0/11 sssssss18
Default Feed back whine from components at low vo
So Iím having a whine feedback issue with my component speakers I donít believe itís an Alternator whine because It does not increase with the RPMs. I may be wrong but not sure whatís causing it I checked the amps ground good, amp is a Rockford p300x2 . Maybe head unit ground?
Old 01-28-2018, 10:26 AM
1/11 ssssss118
How much is the gain up on the amp? I had the same problem with my Rockford amp on my highs i re-did my grounds rcas everything finally read somewhere to check the gains i turned them down and it went away
Old 01-28-2018, 08:42 PM
0/11 sssssss18
Gain is set for -5db with the Rockford clean set up. It has it about a quarter past half way almost.
Old 01-29-2018, 02:27 PM
0/11 sssssss18
Thinking about using a line driver to boost signal so I can run a lower gain
wtb: 6.5 inch coaxials or components por el low low rachidfunaki Wanting to Buy (WTB) 4 02-16-2015 02:02 PM
needing user feed back on these amps ! imnew59585 General Car Audio Discussion & Questions 3 05-10-2013 10:15 AM
Build help , need feed back Gonzo151 Enclosure Discussion & Design Construction Help 0 10-23-2012 05:18 PM
feed for Pacquiao vs Marquez??? jnralp00 Sports and Fitness 31 11-14-2011 04:35 PM
Added new car show feed Patrick Simmons Competition Corner 5 09-14-2008 01:05 PM
