how to deaden back hatch area on hatchback? - Car Audio Classifieds!
Old 02-07-2018, 02:02 PM
0/11 sssssss19
Default how to deaden back hatch area on hatchback?
I have a scion tc and I am about to deaden the back hatch area. most other outer metal panels are deadened already. The hatch is hard because the metal area is actually two layers close together with the top one only having lots of little small holes in it. I can put some foam between the layers but I cant put any deadening material on the outer layer. I was honestly thinking of foaming it, covering the exposed layer and some of the holes with butyl deadening, and then mass loading the plastic that attaches to the metal so that some of sound would reflect more and it would move a bit less (although with probably equal inertia).
I'm wondering if this would be effective or what would for this area? I'm worried that mass loading it would just make it move less but due to the same amount of energy hitting it and it being more massive, it may still shake against the metal with as much noise. I've seen some people just remove the plastic altogether and that helped. Any ideas or experiences are welcome.
Old 02-07-2018, 06:37 PM
0/11 sssssss35
not sure if it helps, but i have I have a 07 CRV. What i did to stop 85% of my hatch rattle was using tennis balls wedged in the rights spots. the clearance between metals on my hatch fits perfect. your vehicle may differ, just throwing idea out there
Old 02-07-2018, 11:39 PM
0/11 sssssss19
Damn that sounds like a really good idea. When I hold the hatch down it makes it rattle ALOT less at least on the outside. I'm thinking a good amount of mass and maybe something like that to apply pressure would do the trick.
to deaden doors, or to deaden hatch (wagon) & diff between "sound deadener" /"cld" randombeat General Car Audio Discussion & Questions 2 01-24-2015 10:46 PM
Back Hatch glass... IowaBass General Car Audio Discussion & Questions 7 10-05-2014 01:35 AM
hatch back help beach72 Enclosure Discussion & Design Construction Help 7 01-21-2013 02:42 PM
Deaden hatch yes or no??? BudgetBass General Car Audio Discussion & Questions 10 09-02-2012 01:48 PM
focus hatch back help focusedfornow Enclosure Discussion & Design Construction Help 3 09-11-2011 08:01 PM
