Soundstream Tarantula T5.122 - 1 Ohm wiring - Car Audio Classifieds!
LinkBack Thread Tools
Old 03-22-2018, 02:26 PM
Brand New Members
0/11 ssssssss4
Default Soundstream Tarantula T5.122 - 1 Ohm wiring
I have a new Soundstream Tarantula T512.2 sub that I am installing in my son's car. I know how to wire a normal push-pin type connector in parallel...but this sub has 8 awg leads.
I know the premise is still going to be the same, but the manual shows wiring the positive from one coil and a negative from the other with no other connections between...this just doesn't sound right.
What is the proper way to wire, and connect (not solder), these 4 wires to make the sub a 1-Ohm sub?
Old 03-23-2018, 10:01 AM
0/11 ssssss275
Connect both positives together, both negatives together. Run them to the amp
X3-122 Soundstream pair Subzero 12" Subwoofers 9 08-11-2012 02:15 PM
12 inch Soundstream Splx-122 powerhx2 12" Subwoofers 2 03-31-2011 01:24 PM
FS:soundstream splx-122 SUBW123 12" Subwoofers 5 03-16-2010 04:45 PM
soundstream splx 122 quaddropper General Car Audio Discussion & Questions 0 07-21-2009 09:20 PM
