Battery Wiring 2 Ways Any Difference? - Car Audio Classifieds!
Old 03-31-2018, 10:39 AM
only126db's Avatar
The One U Love 2 Hate
0/11 sssss2943
Default Battery Wiring 2 Ways Any Difference?
Wondering if I would notice any difference in charging or output depending on which way I were to wire my batteries. One way would be much more economical than the other, both ways would be fed to junctions (feeding multiple amps) and both ways are parallel...
Old 03-31-2018, 11:39 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Sent from my SamsungLife using Tapatalk
Old 03-31-2018, 11:58 AM
massivespl's Avatar
0/11 sssss8409
U want positive to go to the first battery in the back and the negative on the last battery in the back and then connect all the batts together so they charge evenly. If u don’t they don’t charge the same
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-31-2018, 01:45 PM
only126db's Avatar
0/11 sssss2943
That would be like #1 ? I currently have pos from underhood batt to a terminal then that feeds 3 amps their pos signal. I have neg from battery going all the way back to another terminal feeding ground to the 3 amps. In an ideal world I would have designed the setup to run multiple batteries but I didnt, so without ripping my entire interior out I can either do 1 or 2 from the drawings...The dots in front of the amp (which is actually 3 amps) are the terminals where my 4/0 is attached, then 4g runs to each amp (2 Cadence TXA's and an Earthquake 200dhc for the subs).
Old 03-31-2018, 02:32 PM
massivespl's Avatar
0/11 sssss8409
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-31-2018, 03:22 PM
only126db's Avatar
0/11 sssss2943
How much of a difference would there be between 1+2 on output, would the draw be any different between wiring styles?As for charging, lets assume I throw a charger on the vehicle over night every couple days or give it a break from pounding to get a good charge on them. Your drawing is like #2 but for my setup #2 wil require much more power wire since each extra bat has to straddle my enclosure.
Old 03-31-2018, 09:43 PM
massivespl's Avatar
0/11 sssss8409
It prly wont make much of a difference because u only have two batts back there but if u had a bank of batts you would want to wire how my drawing is
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-31-2018, 09:48 PM
only126db's Avatar
0/11 sssss2943
Ok, didnt think it would matter that much in my case, just wanted to be sure....I just need some voltage before my stuff fries, my truck looks like a rolling strobe light...
Looking for ways to improve my Eclipse 3 ways mid bass? AuZy_AuDiO General Car Audio Discussion & Questions 16 01-29-2014 06:12 PM
Wiring battery bank from alt or front battery burzendowski General Car Audio Discussion & Questions 9 02-15-2012 05:36 PM
Wiring battery banks help burzendowski General Car Audio Discussion & Questions 10 02-04-2012 09:26 PM
t/s spec difference in wiring impedance. Violence* General Car Audio Discussion & Questions 21 03-02-2011 04:14 PM
wiring up additional battery. quaddropper General Car Audio Discussion & Questions 8 03-13-2010 04:37 PM
