Don't know specs on this 15'' Eclipse sub. Need help. - Car Audio Classifieds!
Old 05-01-2018, 01:07 PM
Brand New Members
0/11 ssssssss1
Default Don't know specs on this 15'' Eclipse sub. Need help.
Got this old 15 inch Eclipse subwoofer. Can't find any info on it
On the side of the speaker there are two stickers,
One says "87151.7 8ohms Made in Taiwan"
The second sticker says "87151.8 107, Z9200176"
Tried looking them up and couldn't find shit. Ive had this speaker for years i bought it cheap as hell at a pawn shop and it bumps and sounds very very nice even in a shitty box i built but id like to build a real box now for it.
Old 05-13-2018, 06:19 PM
0/11 sssssss91
Ripped that off from another forum I'm on, but its what I could come up with
87121.4
Fs 27Hz
Qts 0.43
DCR 4.0Ω
Vas 1.85 Cuft
Xmax (one way) 0.73˝
Continuous Power Handling 300W
Music Power Handling 600W
Features
•1˝ santoprene surround
•One-piece Mica-Filled Polypropylene (MFP) cone
•CONEX®
dual spider with woven-in tinsel leadwires
•Kapton voice coil former
•4-layer long-throw voice coil
• “Bottomless” design
•Vented pole piece
•Cast aluminum frame
•Double-stacked magnet
•Small sealed-box enclosure
material.
ECLIPSE 87001 series subwoofers employ MicaFilled Polypropylene (MFP) cone material for
superior rigidity with low mass. The stiffness of
MFP enables ECLIPSE woofers to maintain
excellent distortion characteristics under intense
power applications. The low mass of MFP
ensures bass reproduction that quickly reacts to
the input signal for “count the cycles” accuracy.
MFP’s lightness also increases driver efficiency,
providing more output per given watt of amplifier
power.
1-inch wide santoprene surround.
One-inch wide, 1/2-inch tall surrounds provide a
long, controlled stroke. Santoprene synthetic
rubber is weatherproof, very pliable and durable
at all temperatures and has excellent damping
characteristics to reduce cone resonance
distortions.
• Kapton voice coil former
Handles a significant quantity of heat without
deforming.
• Long-throw bottomless motor structure
Prevents the speaker from “bottoming out”
even during high-power dynamic peaks.
• CONEX®
leadwires
• 2-inch (2.5-inch 87151.4, 87151.8) voice
coils
• Small sealed-box designs
• Cast aluminum frame
• Double-stacked magne
FS) 2 New Eclipse 8808 8" subs & 2 New Eclipse XA1000 Amps brirat Car Audio Packages 0 05-11-2011 03:27 PM
Eclipse SW6082.8 specs? bergend2 General Car Audio Discussion & Questions 7 12-22-2010 09:33 PM
need specs on eclipse titanium cone 12's mineralgrey01gt General Car Audio Discussion & Questions 1 12-05-2010 05:17 PM
differences from Eclipse 88120ti dvc and Eclipse SW9122??? nefariouscaine General Car Audio Discussion & Questions 5 08-18-2010 05:41 PM
don't know if I will be on korey_hofer Off Topic Chat 10 12-15-2008 07:21 PM
