Wire ferrules and KnuKonceptz power cables? - Car Audio Classifieds!
Old 05-15-2018, 02:31 PM
Brand New Members
0/11 ssssssss2
Default Wire ferrules and KnuKonceptz power cables?
I've searched everywhere and I can't find any definitive answers on what wire ferrules will "properly" fit on the Kolossus Fleks Kable 1/0. Their website states that the approximate size of the actual wire is around 12mm and I have been able to locate ferrules with an inner diameter of 11.8mm or 13.5mm both of which are actually 2/0 ferrules. I figure I will order both sizes but before I order anything I was wondering if anyone has found anything that fits properly without having to trim a bunch of strands that won't fit or have the ferrule be to loose?
The 4awg ferrules I bought for the 4awg Knu cable that I have are way to small so I am trying to avoid that this time around!
Old 05-18-2018, 11:45 PM
jmpbama92's Avatar
0/11 sssssss11
I would try Ebay or Amazon, also I will give you a tip. Fill the ferrule with solder to keep the ferrule from mashing because this prevents heat and friction.
Anyone use wire ferrules ? miller83815 General Car Audio Discussion & Questions 24 02-13-2016 04:42 PM
Can you use KnuKonceptz power wire as speaker wire? DevinG17 General Car Audio Discussion & Questions 16 02-29-2012 03:27 PM
Need some patch RCA cables and maybe power wire? !! mattintc10 Wanting to Buy (WTB) 3 11-20-2011 06:58 PM
KnuKonceptz KCA Black 1/0 Gauge Power Wire 20 Feet teambagboy1 Wiring, Electrical & Other Installation Equipment 2 04-21-2011 10:56 PM
[SOLD]FS: 20' Knukonceptz 1/0 Red Power Wire Pillow Wiring, Electrical & Other Installation Equipment 7 11-10-2010 09:40 PM
