How Do You Test Your Alternators Output? - Car Audio Classifieds!
Old 05-20-2018, 05:34 PM
only126db's Avatar
The One U Love 2 Hate
0/11 sssss2943
Default How Do You Test Your Alternators Output?
I bought a Hi Output Alternator (supposedly) and dont have a load tester so what I did was hook my clamp meter on Alternator main cable, put my DMM on Battery terminals and with all my accessories on (heater, brights, fog lights) I watched the amperage and voltage at idle, it was very unimpressive, rather sickening actually. Then at 2100-2200 rpm I did the same but with my system running a 40hz tone at full tilt.... I know this wouldnt give me total capability of the alternator but I believe it clued me into this alt being a total fake.
Tell me if I am wrong....with an alt capable of 150 @ idle and 300 @ 1200 rpm I shouldnt have had a whole lot of voltage drop @ 2200rpm drawing 190 amps correct....
Old 05-22-2018, 10:56 AM
0/11 sssssss19
Are you getting voltage drop from draw or is your voltage without draw low to start with?
If your voltage is low when starting the car and no load from the amps then it could be your voltage regulator.
I know I was unimpressed with my mechman 240 because the voltage regulator on my car kept it the same as the stock alt. About 13.9 when I start the car. Drops to about 13.5 after it heats up over an hour. Drops by about 0.5 volts when hitting the solid notes at full volume. Its just the voltage regulator in my case. Steve meade even did a video on how he had to get a voltage booster to go between the cars voltage regulator and the alternator to get 14.4 out of a mechman.
Old 05-22-2018, 11:39 AM
only126db's Avatar
0/11 sssss2943
Voltage fluctuated way more than I liked, I only have a main 150A fuse, alt was supposedly rated @ 300A @ 1200rpm, I pulled a peak of 190, average around 160's but voltage dropped down to just over 12V before I shut down my test. My test was a 40hz tone playing through my system which was only one 1600rms @12.5v class D amp. If I drove my truck @ 3000rpm cruizing down the hwy no system or accessories on voltage being monitored through my OBDII port my voltage bounced from 12.5-15V.....I am sending alt back today....
When I put old alt back on, voltage was much steadier and more predictable, increase volume, voltage goes down, lower volume, voltage goes up....etc Problam is, alt is weak and only pushing 115A
Old 05-23-2018, 01:44 PM
Azalin_00's Avatar
Baller on a Budget
0/11 ssssss255
I’m having the same problem with my 320a hairpin. Voltage spikes, voltage drops, and on only saz 1500. Lights and dash dim before I reach full tilt and unsteady voltage worries me. I got the alt new and installed it with a brand new agm as well, but still doesn’t seem to be able to push the 1500.
2014 F-150 Supercrew (Daily driver) Stock
1997 Chevy Tahoe (Parked) (2) 24" SHDs and all the fixings coming soon!
Old 05-23-2018, 03:00 PM
0/11 ssssss543
Sounds like belt slip common on ho alts if running a smaller than stock pulley. Might need a better wrap or tighter belt. A smaller belt is easier than adding an extra pulley to add contact area but sometimes you will need to increase contact area.
Old 05-24-2018, 09:39 AM
only126db's Avatar
0/11 sssss2943
I wish it were belt slip, not though.... When I told seller the issues they didnt even try to have me troubleshoot it, they just said send it back.
Js Alternators Bench Test 275amp 6phase hairpin (284amps) JsUltimateSounds Testing & Scientific Data Discussion 1 06-06-2015 02:20 PM
High Output Alternators califaplayer707 General Car Audio Discussion & Questions 21 07-02-2013 01:48 PM
Overstock Sale! GM high output alternators! MECHMAN General Car Audio Discussion & Questions 39 01-13-2012 08:35 AM
WTB 2 hi output gm alternators loud avalanche Wanting to Buy (WTB) 17 11-14-2010 02:51 PM
