Flickering headlights not related to power draw - Car Audio Classifieds!
Old 09-25-2018, 08:57 AM
What did you say?
0/11 sssssss17
Default Flickering headlights not related to power draw
2005 Dodge Neon SXT. Stock alternator and external voltage regulator set to run at 14.2 volts.
My headlights flicker independently of any load put on the alternator. Even with a fully charged battery and no other accessories turned on but the headlights, the headlights still flicker. I have checked for A/C voltage in the electrical system but have none. The Big 3+ has been done. Im suspecting an alternator problem but it is still charging. Anyone have any ideas on this?
Old 09-26-2018, 01:41 PM
0/11 ssssss543
Have you checked with a volt meter in different locations while it was happening? Battery alt main vehicle fuse box
Old 09-26-2018, 02:27 PM
What did you say?
0/11 sssssss17
Yes I have but my Fluke has a slow sample rate so it shows steady voltage everywhere. It’s not just the headlight circuit either as my dome light flickers at the same rate as the headlights.
Old 09-27-2018, 10:26 AM
0/11 sssssss24
Default low lux
headlights work on a relay // if the relay is old it can break down inside
they are pretty cheap // if you did the big 3 then jumpering a relay for testing should be straight forward//
so if its just the head lights you need to determine if its before or after the relay/// I suspect after the relay and a new headlight relay may resolve it /// you might put a screwdriver from the plastic on the relay and to your ear listen and see if you hear anything // have some one turn the lights off and on// should be a solid "click" and then silence //
I would also check the ground //
fender ground wires tend to get tossed and usually there arent any issues but they are put there for reasons such as this //
good luck and keep us posted //
last but not least when its dark try and look around and see if there any arcing also listen this kind of failure usually has a fuzz noise with it
Old 09-27-2018, 10:30 AM
0/11 sssssss24
Default low lux
ps its not your alt! //save your money// you said w/o stereo it still flickers, your battery would smooth out any pulses like that
Old 09-27-2018, 01:57 PM
What did you say?
0/11 sssssss17
The dome light flickers at the same rate as the headlights and is on a different circuit than the headlights so that should rule out a bad relay, right?
I think I’ll try to unplug the alternator control circuit and run the car with the headlights on at night. If the flicker goes away then the problem has something to do with the alternator but if it continues then I have to look elsewhere.
Old 09-27-2018, 09:49 PM
What did you say?
0/11 sssssss17
Alright, I disconnected the external voltage regulator, started the car, and turned on the headlights. Voltage was steady at 13.2 volts, and no flicker at all. So I shut the car off, plugged the regulator back in, started the car up with the headlights on and the flicker is back.
With the factory computer controlling the regulator duties, the flicker was present. With an aftermarket external adjustable voltage regulator the headlights flicker as well. So either 2 different voltage regulators are bad, or something is not right with the alternator.
Old 10-03-2018, 09:23 PM
What did you say?
0/11 sssssss17
Anyone have an idea on this?
Old 10-04-2018, 11:05 PM
What did you say?
0/11 sssssss17
Also, as part of the Big 3+ that I did, all of the underhood grounds have been connected to the battery ground via multiple 4 gauge cables. So the upper radiator core support ground wires for the headlights has a 4 gauge ground cable running to the battery. All grounds in the engine bay have been cleaned, resecured with stainless steel hardware, then covered with a liberal coating of dielectric grease.
Before I did all of this the headlights flickered just as they do now.
Old 10-06-2018, 06:21 AM
only126db's Avatar
The One U Love 2 Hate
0/11 sssss2943
Did you install LED's ?
Steady power related questions regizzle General Car Audio Discussion & Questions 6 12-06-2011 03:44 PM
Not audio related, i need someone to help me masterbarber Off Topic Chat 5 10-21-2010 05:22 PM
Electrical problem? Big 2/3, 3 batts. And lights/ACC is flickering when cars on?? AuZy_AuDiO General Car Audio Discussion & Questions 8 04-08-2010 03:07 PM
WTB: Stetsom, Cactus, Atomic or any AMPLIFIER related in Power.. 6k + rms Prodigy215 Wanting to Buy (WTB) 8 11-30-2009 08:36 PM
Lights flickering (interior and exterior) Ryan1126 General Car Audio Discussion & Questions 35 10-13-2009 09:26 PM
