Power separation - Car Audio Classifieds!
Old 10-01-2018, 08:21 PM
0/11 ssssss154
Default Power separation
I got the LL100ah for my audio and 2 yellow tops under the hood to run the vehicle and other stuff(winch, compressor, lights, etc). Have the stock alt for under the hood and a singer320 for audio but want to combine them without affecting each other(parasitic draw). I have an isolator relay for the front but need to know do I need relays on all runs to the lithium from both alts, just the shared(370a in future), or no relays at all?
DO NOT TELL ME TO ELIMINATE THE FRONT BATTS!
That may be fine for others, not me. Still have a year left on warranty
Old 10-19-2018, 12:02 PM
jmpbama92's Avatar
0/11 sssssss11
Maybe, depends on certain ways you wire it up. I know you definitely need a fuse under the hood on the long run to your audio battery. Is the 2nd alternator connected to your front batteries? If so, you need an isolator. You only want so much voltage going to your front batteries.
The Following User Says Thank You to jmpbama92 For This Useful Post:
455dscdbh (10-21-2018)
Old 10-22-2018, 09:49 AM
0/11 ssssss154
Default Alts
The future 370A will be for the 2 in the front which are isolated on the stock alt right now.
How to fix a spider to former separation Anton Miller Tutorials & Quick References 4 01-08-2014 06:59 PM
Power, power, power!!! Bradleyj0808 General Car Audio Discussion & Questions 5 02-03-2011 11:31 AM
[FOUND] on CL..O/S RF Power 650 or Power 1000 mosfet beatnbronco Bargain Bin 7 06-06-2010 11:27 AM
[SOLD]F/S - XS Power S925 w/ XS Power #527 GM Adapter SundownAudioNY Wiring, Electrical & Other Installation Equipment 10 04-23-2010 08:35 AM
How to become a CACO Power Seller in the Power Seller Program Patrick Simmons CarAudioClassifieds' Power Seller Program 152 10-20-2008 11:56 AM
