ok here is my question
I have 2 4 ohm dvc 10s rated at 500 rms each skar audio vd-10
I wired em to 2 ohms each box and am currently running a jbl gtx 500 series at 4ohm I figure 350 rms and its pretty good.
I had to improvise and I stuffed the shallow 10's in old kicker boxes.
I have a 1 ohm stable amp at 1000 w rms with low pass and bass boost if needed and this one has an actual bass knob I have an inline gain control add on
is it worth it to go 1ohm and 1k?
its pretty loud at 350 w at 4 ohm and shakes like crazy on the low stuff.
Pioneer avic 5000nex head unit using 63hz crossover on the unit. jbl gtx 500 amp separate amp 70w rms x2 and skar audio 6x8 in the doors at 63 hz as well
Toyota Tacoma 2003 single cab pre-runner.
4 gauge welding wire for power and ground circuit breakers for protection.
I know that was a bit of a question but I wanted to get all the details needed
and I finally answered a question I had for those who are interested
one 10 inch 500w sub @ 500w rms 2 ohm or
2 10 inch at a higher ohm so 350w rms the winner is 2 at 350 rms
