What 6 1/2 sub to go with? - Car Audio Classifieds!
Old 11-08-2018, 11:54 AM
What did you say?
0/11 sssssss17
Default What 6 1/2 sub to go with?
So I’m beginning the research process for my next vehicle(Fiat 500 turbo) and I’m looking at multiple 6 1/2” subs. It will be ran off of the factory amp which is rated at 46 watts X 2 @ 2 ohms. So I am looking at dual 2 ohm 6 1/2” sub(I’m only going to run a single sub). The box also must be smaller than 1 cubic foot.
Here are some of the subs that I have found that meet the criteria;
Sundown SA V.1
Ampere Audio 2.5 RVE
SKAR Audio EVL-6.5
CT Sounds Meso
Memphis 15-PRX6D2
KICKER Cwrt672 CompRT
Digital Designs 506D
If there are any other ones that I missed then let me know. So which one would work best in this application? 92 watts(46 watts X 2 at 2 ohms) total and a box no larger than 1 cubic foot to save the small amount of cargo room that it does have.
Last edited by 91cavgt; 11-08-2018 at 03:03 PM. Reason: Found another sub to add to the list
Old 11-08-2018, 07:03 PM
0/11 sssssss10
I have a pair of the EVL 6.5's. They are ok but mechanical limits are slim.
The Following User Says Thank You to bonzo For This Useful Post:
91cavgt (11-08-2018)
Old 11-08-2018, 08:57 PM
What did you say?
0/11 sssssss17
Thanks for the info on those.
Old 11-09-2018, 08:16 AM
0/11 sssssss10
It would be a toss up on the Sundown Audio X 6.5 V.2 the CT and the DD's. But I realize you have a power restriction. Maybe look into Massive or even DS18 see if something meets your power range.
Old 11-17-2018, 12:40 AM
jmpbama92's Avatar
0/11 sssssss11
I would definitely go with the Skar EVL, you will not be disappointed.
The Following User Says Thank You to jmpbama92 For This Useful Post:
91cavgt (11-22-2018)
Old 11-18-2018, 02:23 PM
Uzi4life991's Avatar
0/11 sssssss36
I love massive audios sumo 6.5s. I'm using them as my midbass, 3 per door in a sealed application for 45hz-120hz range. Best frame/magnet I've seen on a 60$ 1.5" coil speaker! Cast non stamped basket direct leads. I'd like to see a speaker that beats this for the price.
Sent from my SM-N950U using Tapatalk
Old 11-18-2018, 02:33 PM
0/11 sssssss10
I have been wanting to try those massive summo 6.5 for a while now they look stout!!!
Old 11-18-2018, 02:36 PM
0/11 sssssss10
Uzi4life991 Do the massive sumo 6.5's bottom out easily?
Old 11-18-2018, 02:43 PM
0/11 sssssss36
no idea yet. The old EMF audio coaxials they are replacing are loose as hell compared to these stiff buggers, I can't push them 1/4 down without worrying about damaging the cone. I would say the coil would probably go or the spider would rip before they would bottom out especially if you kept them above 40hz which a 6.5 inch speaker definitely isn't made to play much lower than.. I looked at all 6.5 subs and thought these where the best for the dollar! I challenge someone to find me a better quality 6.5 for only 58$ on eBay. Looking forward to hearing all of them in my doors!
Old 11-18-2018, 03:27 PM
0/11 sssssss10
I always had that 100hz to 40hz gap in my system. I see what your going for with these. I like to see how far I can take limits on coils suspensions and what ever else is gonna come unglued. I am running two evl skar 6.5's to the numbers box and I can just about move my wipers lol. Now this is in a 01 vw beetle just about peak watts maybe a little dirty. Im looking for a zv5 10 frame and motor. I got a drop in for my old one and someone baught it from me regardless of the spider tear. I have a cab 1600.1 I like running. sold the x8's and scv 2000 I like them as well.
Uzi4life991 (11-18-2018)
Go Pack Go Dunbar91 Sports and Fitness 161 09-05-2014 04:35 AM
go sealed or go smaller? Stevie General Car Audio Discussion & Questions 35 07-23-2014 09:39 AM
exide car battery go or no go? imnew59585 General Automotive Chat 0 03-30-2013 10:10 AM
Time to go with an SQ setup, but don't know what to go with... SubbinBlazer General Car Audio Discussion & Questions 55 05-16-2011 11:35 PM
which sub would you go with? luises14 General Car Audio Discussion & Questions 30 09-13-2009 12:27 PM
