Originally Posted by BoomBoomBoomBBoom
I didnt know if you turn an amp down it changes the ohms. I thought it was all about the wiring. Can someone school me on this ??
I will assume you are truly not understanding what was written.
I am so sorry. I forgot a coma sir .
since you are keeping it turned down, series will get 6 ohms
that would be safe
this was in reference to the fact the original post said "if I order a 2nd woofer I will have 1.5 ohms" indicating he was going to wire in parallel.
Since this was an assumption I made from the fact that 1 woofer was 3 ohm and it was noted this would net 1.5 ohm. I am assuming a 2nd woofer. so if it were wired is series that would add 3 ohm and 3 ohm and make 6 ohm. this would be well within the range that the kicker would have plenty of power and be a safe ohm load. since the original post advises he was keeping it down this ohm load would be in line with what he wanted
