Wiring a second battery? - Car Audio Classifieds!
Old 11-17-2018, 03:37 AM
Brand New Members
0/11 ssssssss4
Default Wiring a second battery?
Hello, I have a roughly 3500 Watt system. I'm my 16 chrysler 200 with a stock 160 amp alternator. Volt meter tests show at idle at full blast I won't drop below 12.2 volts at the battery. I did the big 3 and I have 1/0 cable ran now. I have done some research and I think my best option is to add a second battery. I plan to ditch the spare tire and mount it there but my wiring options confuse me.
I see it is common to run from the main battery to the second battery then to the amp. Well I already have my system set up where my main power cable goes to a distribution block just behind the rear seat and then goes to each amp. I have a spare connection on my distribution block could I hook the second battery there? Effectively putting the amp in between the 2 batteries?
Or could I run another power cord under the car to the new battery and then to the distribution block?
Old 11-17-2018, 10:23 AM
newarkbeast973's Avatar
0/11 sssss7810
Just replace distro block with a fuse holder. Then run that to the battery. If your distro block is one of the fused one, then run the wire from the 2nd battery to block and then from the block to the amps.
Hope that helps
New build coming soon!!
Old 11-22-2018, 07:15 PM
What did you say?
0/11 sssssss17
I have a 2005 Dodge Neon with a stock 120 amp alternator, an external voltage regulator, the Big 3+, and 1/0 gauge wire ran from the under hood battery to the back at my distribution block. I too had an extra connection not being used so I wired up two Dekka 98 amp/hr batteries under the sub box in the spare tire well(they each have their own 120 amp fuse). There is a Hifonics amp clamped to 1300 watts running the subs and then a 4 channel amp running everything else.
With the engine at idle the voltage dropped to 13.7 volts when it registered a 137.6 dB on music.
Oh, I also have a constant duty solenoid wired up on the 1/0 gauge wire going to the trunk. This is to isolate the starting battery from the stereo batteries.
Old 11-22-2018, 08:33 PM
What did you say?
0/11 sssssss17
Oh, and there is 4 gauge wire from the batteries to the distribution block.
Second battery vs Stinger as main battery Sanders0492 General Car Audio Discussion & Questions 2 10-08-2013 09:18 PM
Wiring battery bank from alt or front battery burzendowski General Car Audio Discussion & Questions 9 02-15-2012 05:36 PM
Wiring in a second alternator grimreper912003 General Car Audio Discussion & Questions 0 02-02-2011 10:13 PM
wiring a second alternator?? audiobahnfan General Car Audio Discussion & Questions 3 10-03-2010 04:01 PM
Wiring in second amp splicing question slimjig General Car Audio Discussion & Questions 6 04-02-2009 10:59 AM
