Help with audio build - Car Audio Classifieds!
Old 12-14-2018, 09:29 PM
0/11 ssssssss9
Default Help with audio build
Hello,
I am trying to run two Orion 15's the HCCA152 2ohms at 2500watts RMS each. Im looking for a 1ohm stable amp thatll work for these. I was looking at the Orion HCCA5000.1.
The biggest alt for my car I can get is a 270A which I will be getting either from Mechman or Singers.
I would like to know if theres any other suggestions on an amp to use for it, but I would also like to know which battery I should be using to run this system and how many. Also a good mid/highs amp as well.
Old 12-15-2018, 09:20 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
You can't wire 2 D2 subs to 1ohm...
Sent from my SamsungLife using Tapatalk
Old 12-15-2018, 12:59 PM
0/11 ssssssss9
Sorry, wiring two 2 ohm.
Was thinking of the orion 8000 watt that puts out 5600 watts RMS at 2ohmms.
Any suggestions would be appreciated as well
Old 12-15-2018, 01:05 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Gotcha, that amp will work.
Sundown, Crossfire, DC make great amps also
Old 12-15-2018, 11:04 PM
0/11 ssssssss9
I came up with this I had seen in a build a few years back.
The 2 orion subs. 2 XS Power d3100s. Taramps HD8000 amp (Could use the orion instead if it fits the build). 270A Mechman alternator.
Would this all work fine?
Old 12-16-2018, 05:16 AM
0/11 ssssssss9
I am actually thinking strapping two monoblocks, either the https://soundqubed.com/product/q1-2200-2-amplifier/ or the SSA ICA2200.1 strapped
Old 12-18-2018, 03:21 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Run 1 amp per sub.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 12-18-2018, 03:44 AM
0/11 ssssssss9
Originally Posted by Boomintahoe View Post
Run 1 amp per sub.
Would I want to strap these in this case? Or run two individual amps non strapped? Ive never done a two amp setup but thats what I was recommended. Im going to be tunning 3 baof the xs power 3100s and was going to run the two amps
2005 f-150 audio build help daveG General Car Audio Discussion & Questions 3 09-05-2015 08:50 PM
New to car audio - Please help with my new build!!! G00burr General Car Audio Discussion & Questions 31 08-22-2013 07:58 PM
i need help on what cross over i should get help help help!!!!!! swayefx New Member Orientation 0 07-09-2013 10:44 PM
Help build the largest car audio repository ever. 807tubenut General Car Audio Discussion & Questions 0 07-01-2011 02:52 PM
4th order port through rear deck need design help, and build help in MN or IA area maddog2099 Enclosure Discussion & Design Construction Help 6 05-21-2011 10:19 PM
