Grounding issue !!!? - Car Audio Classifieds!
Old 01-19-2019, 01:12 PM
0/11 ssssssss6
Default Grounding issue !!!?
Ok Im in the process of starting my build and decided to upgrade my wire for my doors since the factory wire is a bit old. In the process I have found my head unit is grounded through my antenna. Im lost on this should it be that way ? Any help would be appreciated.
Old 01-19-2019, 07:11 PM
truespartan9584's Avatar
Team Ungodly Powers
0/11 sssss1524
Feedback Score: 50 reviews
I’ve never seen that. Don’t you have some sort of interface wire adapter for your stereo that plugs to your car speaker wires?
Old 01-19-2019, 07:56 PM
0/11 ssssssss6
I do. But Im not using it due to me wires are old and I changed out my door speakers . I only use it to power my radio. But even if I dont use it my head unit will power on without the ground connected if the antenna is plugged in.
Old 01-19-2019, 08:22 PM
Team Ungodly Powers
0/11 sssss1524
That’s kind of odd to me. Can you post any pics of the wiring for us to see
Old 01-19-2019, 10:10 PM
0/11 ssssssss6
I can tomorrow.
Old 01-19-2019, 10:11 PM
Team Ungodly Powers
0/11 sssss1524
Ok man
Old 01-20-2019, 07:55 PM
0/11 sssssss24
Default heard of it before
I dont have any answers
did you run a separate ground?
I wondered when I had the issue if it was a reception issue
Old 01-22-2019, 05:22 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Run a separate ground. There should be nothing running along the antenna.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 01-22-2019, 11:04 AM
0/11 ssssssss6
Ok, I looked it up and from what I found the antenna is supposed to be grounded. I removed the ground wire from the harness and ran it separate so I only have the constant and ignition switch on the harness and I am getting the ground humming now. I tried all the tricks of grounding the rca’s with no change. I will try a different head unit to see if that’s my problem.
Old 01-22-2019, 10:08 PM
Team Ungodly Powers
0/11 sssss1524
It’s possible
The Following User Says Thank You to truespartan9584 For This Useful Post:
Tymazaet4 (01-24-2019)
Pioneer DEH-880PRS w/ pico fuse issue and flex ribbon issue groundpound4200 Broken & Non-working equipment 3 04-15-2013 07:58 AM
outrageous grounding issue RidnClean General Car Audio Discussion & Questions 12 09-27-2010 03:16 PM
Question About Proper Grounding brandonb1029 General Car Audio Discussion & Questions 22 07-31-2010 01:33 AM
amp grounding bjizl General Automotive Chat 5 04-11-2010 08:13 PM
when grounding me amps michael707 General Car Audio Discussion & Questions 3 12-16-2009 11:40 AM
