Wood workers - quick question - Car Audio Classifieds!
Old 04-09-2019, 08:24 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Default Wood workers - quick question
I sealed the under side of my baffle with some Bondo resin, turned out great. Question is, Will wood glue adhere to the resonated parts of the baffle or will I have to sand those areas?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Old 04-09-2019, 08:30 AM
0/11 ssssss100
I would sand the area where you want the glue to stick. Not sure wood glue would hold.
Maybe E6000? or something similar to join the resin to resin
Old 04-10-2019, 08:50 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Thanks, I just sanded the areas. Should be good
Old 04-10-2019, 07:45 PM
0/11 ssssss225
How much is that resin stuff? Iím going to be starting on a box in the next couple days and I think I want to coat the inside. Will it give it more strength or just seal it up?
No, you're is!
Old 04-10-2019, 07:51 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
I paid 16 bucks for mine. I'm not sure about strengthening but, it helps with the air flow, nice and smooth.
Old 04-10-2019, 08:44 PM
0/11 ssssss225
Oh ok, itís cheap enough Iíll probly try it
No, you're is!
Old 04-12-2019, 04:04 PM
0/11 ssssssss7
Originally Posted by Jski1990 View Post
Oh ok, it’s cheap enough I’ll probly try it
. Resin is only useful for reinforcing fiberglass mat it cloth and making a reinforced body filler. Other than that and you're wasting time and $$$$. There are no benefits to sealing MDF unless you need to paint it.
Old 04-13-2019, 02:30 AM
0/11 ssssss225
Maybe Iíll skip that then. Iím not painting, just gonna roll on some bedliner.
No, you're is!
Old 04-13-2019, 05:50 AM
0/11 ssssssss7
Yes resin is misused by inexperienced people thinking it has some magical properties. Poly resin alone is weak and brittle. It only does it's job when saturated in glass cloth or mat. I mean it might slightly weatherproof the MDF but there are dedicated products that do a better job. Where I live resin is super $$$$. I don't buy the Bondo garbage at the parts store and only go for the premium quality stuff. So I learned a long time ago not to misuse it and conserve it at all times. Despite my name which was inspired by my love of fiberglass construction I use it as sparingly as possible. It's just not necessary in many situations.
Old 04-13-2019, 04:43 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Lol!
Dealing with difficult co-workers Boomintahoe Off Topic Chat 31 05-29-2014 03:27 PM
Fast food workers on strike Boomintahoe Off Topic Chat 57 09-03-2013 11:29 AM
quick question need quick answer 05xxx perfect_prefect General Car Audio Discussion & Questions 0 01-25-2011 03:44 PM
Quick question... Answer QUICK please its getting dark soon Sonically_Sound General Car Audio Discussion & Questions 11 10-03-2009 08:41 PM
graveshift workers RidnClean Off Topic Chat 5 07-19-2009 10:30 PM
