Cerwin Vega Stroker Pro 12 - Car Audio Classifieds!
Old 02-17-2010, 11:16 AM
0/11 sssssss11
Default Cerwin Vega Stroker Pro 12
Need suggestions on wiring speaker.... Im using a MA Audion Hk602SX amp and a Stroker Pro 12, any suggestions on wiring? Before when wired i had it bridged but amp would get as hot as 180 degrees and suprised i didnt fry it but that was also due to 4 guage wiring as well, so any ideas or should i bridge it again now that ive moved up to 0 gauge wire. I prefer to ask before i due it because i dont want to make the same mistake twice and this time have an unwanted outcome such as fried amp.
Old 03-05-2010, 11:33 AM
cv-pro's Avatar
0/11 sssssss27
does your amp run 1ohm? if so keep bridged
Old 08-02-2013, 05:00 AM
0/11 sssssss28
I have the same sub and it reads 2.2 ohm per coil. so 1.1 in parallel. I used a db drive on it and gets really hot. Bought a skar audio amp and it works cool. Do some research on your amp and find out if it is capable of 1 ohm. Some cheaper amps say they are stable, but can't handle it for daily use. This is a sub that can handle 2000rms without a sweat. Maybe you should invest in a amp like a digital designs m2b. sundown 2500. Fosgate t2500.1 . These are a some examples of amps that can handle 1ohm and have true rms ratings. This sub requires a 1ch amp.
Old 08-02-2013, 05:03 AM
0/11 sssssss28
Ps: If the amp you use is 2 ch most likely can't handle 1ohm, And at 4ohm is too weak to even move such a powerful sub.
cerwin vega stroker old school 15" 4 ohm psychoacoustics 15" Subwoofers 16 07-27-2010 10:52 AM
wanted cerwin vega stroker pros cv-pro Wanting to Buy (WTB) 4 02-14-2010 06:34 AM
Recone O/S Cerwin Vega Stroker D2 HiloDB1 (Fix My Speaker) 1 07-22-2009 11:17 AM
15" Cerwin Vega Stroker (OS) -Buffalo, NY - $4 SundownAudioNY Bargain Bin 6 06-11-2009 02:58 PM
12" Cerwin Vega Stroker Jshak07 12" Subwoofers 0 12-04-2008 04:09 PM
