Re se12??? - Car Audio Classifieds!
Old 02-17-2010, 12:47 PM
dat517boi's Avatar
0/11 ssssss834
Default Re se12???
anyone running these?
im doing a build for a female friend of mine i have a ap1500 and was thinking of running a re se12.
any input would be helpful
Vehicle: 2000 Jeep Grand Cherokee
Head Unit: JVC KD-R210
Sub: SA Nightshade V.1 18 x2
Sub Amp: Audioque AQ2200 x2
Battery: Optima Yellow Top, 9A31 x2
Alternator: 235 amp alt
can we start the bidding war for the sister and mom?? and can we get T/S parameters on both?
well unfortunately the t/s when they were new will be way diff now.... these drivers are used and beat on pretty hard in there day (not personal use but ive known all the owners and theres been alot)
Old 02-17-2010, 12:50 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
make sure you run it @ 2 ohms, the SE will not like 1500rms lol
and they are awesome subs, except for the new x series
Old 02-17-2010, 12:53 PM
crownvicon26's's Avatar
0/11 sssss1882
You could run two off of that amp. That would be perfect. You could run one of them off of that amp. I would run it at 2 ohms if only running one. You would need a dual 4 to wire down to 2 ohms. Either way great sounding woofers and with that amp she would have power to upgrade if she wanted.
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 02-17-2010, 12:54 PM
dat517boi's Avatar
0/11 ssssss834
yeah i will be running it at 2 it will only see like 900 max and i wont let her push that much ha prolly turn the gains down a bit
Old 02-17-2010, 01:04 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
it can take the 950, my 15" SE did, but just to be sure it doesn't blow, watch the gains a bit.
Old 02-17-2010, 01:10 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
my 15" se is seeing roughly 800 daily and i beat on it. You should be fine as long as you wire it at 2 ohms.
Old 02-17-2010, 01:21 PM
dat517boi's Avatar
0/11 ssssss834
ok thanks alot guys. im about to order it all tonight.
1 RE SE12'
1 ap1500
KnuKoncepts KLM 1/0 Amplifier Installation Kit (250A)
KnuKoncepts Krystal Kable 2 Channel 6M Twisted Pair RCA Cable
Infinity Reference 9622i
Infinity Reference 6032si
all going in a 2002 Chevy Impala
ZX750.1 and SE12 combo for trade madmat Car Audio Trader (WTT) 13 12-05-2008 07:53 AM
