AQ1200, is it a wise choice? - Car Audio Classifieds!
Old 02-17-2010, 01:26 PM
0/11 ssssssss7
Default AQ1200, is it a wise choice?
Ok, looking at the AQ1200 I think its perfect for my choice of subs, I want it to drive Two 12" Alpine type R D4 subs @ 1 ohm, that's 600watt rms driving each subwoofer, (alpines slightly underrated anyway). so is this amplifier suitable? alpines will be in a 4cubic ft box tuned to 32hz.
Thanks!
Old 02-17-2010, 01:29 PM
0/11 sssss1143
that should be a nice match. i had a pair of Rs on around that power and box and it was good combo
Old 02-17-2010, 01:30 PM
0/11 ssssssss7
wow quick reply.
thanks
Old 02-17-2010, 01:32 PM
Drewculous's Avatar
0/11 ssssss679
it'll be good, i ran a couple type-r's on about 1k and it was nice!
alpine makes a good sub, never had any problems with 'em
and i run a couple aq2200s and they are very good amps
If the cops dont come, your not doing it rite.
Old 02-17-2010, 01:33 PM
0/11 sssss4714
Very good match for those Rs, and with AQ you just cant go wrong, good CS, and amps are rock solid, you cant go wrong!!
TEAM GORILLA
TEAM GHOST MOB
2007 Ford F150
1995 T-Bird P.I. 4.6L 312rwhp-Comp car,work car
Trunk Car class for 2011 MidwestSPL division!!
Old 02-17-2010, 01:41 PM
Bushj311's Avatar
0/11 sssss5532
Feedback Score: 45 reviews
Aq makes a great amp and has great customer service. Good pick on that amp. check into 2 aq sdc 2.5s over the type rs
Old 02-17-2010, 01:53 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
x2
Old 02-17-2010, 02:03 PM
TurdFergueson2's Avatar
0/11 sssss3902
I thought R's in the right hands could take a lot more than 600. I was thinking get the 2200 and give the Rs 1k each
Old 02-17-2010, 02:10 PM
0/11 ssssssss7
lol I'm using the type R subs because I love them, and the SQ is amazing.
Anyway, no Type R's will not take 1200wrms CEA rated watts, I've seen this dude on youtube "monkeypumper420" blow one with about 750wrms just to prove they cant take more than 700wrms daily.
Old 02-17-2010, 02:27 PM
Bushj311's Avatar
0/11 sssss5532
Type rs can take more then 750 rms. Depends on a bunch of different factors.
AQ1200 Serious Problem..... NathanLewis General Car Audio Discussion & Questions 45 02-17-2010 12:37 PM
whats the tool of choice for this? waresgaragestereo Sound Deadening & Fabrication 29 08-05-2009 06:18 AM
2nd Annual Independence Day Car Show ~ Wise NC ~ 07-04-2009 CACO's Car Show Bot Car Show Feeds 0 06-22-2009 02:00 AM
Best choice in a ext. cab truck? truckcap22 Enclosure Discussion & Design Construction Help 8 03-16-2009 10:08 PM
Deck Choice RidnClean General Car Audio Discussion & Questions 8 10-16-2008 09:38 AM
