Orion Hp 12's vs AQ sd.c - Car Audio Classifieds!
Old 02-17-2010, 03:30 PM
NathanLewis's Avatar
0/11 ssssss947
Default Orion Hp 12's vs AQ sd.c
Im sick of the sub I have, it can't handle power at all for a daily driver on the low notes. High notes, seems to do fine.
I was looking At Orion Hp 12's, rated 500 rms, I want to get two of them, put them in a box tuned to 33. Would you think this could get louder than an Ma audio Hkx12 @ 1500 rms? More cone area = more air moved?
Here are the specs on the orion, each sub cost 179$ I want two.
Vas.2: 1.79 cu ft
Vas.4: 1.78 cu ft
Sensitivity: 87/ 85dB
Linear Excursion: 14mm
Dimentions: 11"/ 7"
Power Handling 500 Watts RMS / 1000 Watts Peak
Machined Custom Die-Cast Basket
Open Loop Motor Design
Metalized Poly Cone and Medium Roll NBR Surround
Tight Small Sealed Box Performance
Custom Tooled Reversible Wrap Gasket and Protective Magnet Boot
Heavy Gauge Wire Terminals
2.5 Inch Voice Coil on Aluminum Former
This or AQ sdc2.5's?
F/s/t 2 re xxx 12's mattakared 12" Subwoofers 30 05-22-2010 12:00 AM
2-12's in box 00walledcavi 12" Subwoofers 1 07-17-2009 08:10 PM
(2) JL W6 12's!!! 350zkid Bargain Bin 2 06-08-2009 12:10 AM
WTB 4 12's peas247 Wanting to Buy (WTB) 4 04-28-2009 04:38 PM
