would this be enough battery for my amp - Car Audio Classifieds!
Old 02-17-2010, 07:40 PM
alexis8284's Avatar
0/11 ssssss913
Default would this be enough battery for my amp
i have a cadence c5 and i am changing out my old batteries. i found a good deal on red tops, so i am going to pick up 6 . one under the hood and 5 in the back. do you think that would be enough juice, never dealt with the redtops.
Old 02-17-2010, 07:53 PM
Slam's Avatar
I slam
0/11 sssss3772
how much?
Old 02-17-2010, 07:54 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
I always thought red tops weren't made for car audio applications, and they suck IMO.
Old 02-17-2010, 07:55 PM
alexis8284's Avatar
0/11 ssssss913
i can get them under 70 each but they are local pick up
Old 02-17-2010, 08:04 PM
98AckCL23's Avatar
0/11 sssss9929
Even at that price, I still wouldn't run them...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 02-17-2010, 08:06 PM
alexis8284's Avatar
0/11 ssssss913
what is bad about using them
Old 02-17-2010, 08:07 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
Id say use one for your front battery maybe. I picked up at Red Top from a buddy for $50 and I think it was well worth it. Starts up the car easily and quickly every time even in 0 degree weather this winter. I have pretty decent voltage too with a stock alt on a first gen Neon so prolly not so many amps from that maybe 65-90A if im lucky and all engine grounds and BIG 3 in 4 gauge pure copper (I know not 1/0 yet...) and my voltages at idle (900-1050rpm) drops to lower 13s at full tilt at the lowest so Id say it can put out some juice. The amp is rated at 1200rms and fused for 120amps running at one ohm.
Anyways Id say scoop up one for the front or if you want to I think you could use the others in the rear but there is better out there and if I took the money you would pay for 5 of the redtops at 70 bux I would have 350 to spend on an excellent battery or two very nice ones.
Its up to you in the end and what kind of rms wattage do you plan to be running?
Slam's Avatar
I slam
0/11 sssss3772
u should just get 2 of my batts
Old 02-17-2010, 08:16 PM
0/11 ssssss825
Feedback Score: 24 reviews
The red tops are made specifically for starting applications meanwhile the yellow tops are for deep cycle. So for your application you would want to go with a yellow top or some other deep cycle battery.
Battery for my CRV? andrewtexas123 General Car Audio Discussion & Questions 2 03-09-2010 10:26 PM
What do you think of this battery? KeepinItSimple General Car Audio Discussion & Questions 2 02-06-2010 03:15 PM
battery help crownvicon26's General Car Audio Discussion & Questions 15 10-23-2009 11:54 PM
WTB: Battery kentb Wanting to Buy (WTB) 2 10-17-2009 03:42 PM
What Do You Think About This Battery? duramaxxed General Car Audio Discussion & Questions 21 09-29-2009 01:55 PM
