DD M1A @ 1/2 ohm? - Car Audio Classifieds!
Old 02-17-2010, 08:29 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
Default DD M1A @ 1/2 ohm?
I saw maybe two people on forums somewhere running the DD M1A at half ohm and I was wondering if it would be ok to do as long as I watch my voltage or is this a bad idea.
The reason why I would be doing this is because I want to get another sub and my sub is D2 so it is wired to 1 ohm now to get the most potential from the amp with the single sub setup and if I got another D2 I could wire them to .5 or 2 ohms and 2ohm would be maybe 3-400w a piece and thats not enough. I could potentially get 600rms plus per woofer at .5 and might be ok after box rise anyway?
Let me know what you think both facts and opinions.
Thanks
Also I would be upgrading the amp at some point but not sure when depends on funds.
Old 02-17-2010, 08:39 PM
never heard of a dd mono that wouldn't run under 1ohm no problems, this one is a different design that the older dd's though so not 100% sure
