if this is the case, why do my lights dim?? - Car Audio Classifieds!
Old 02-18-2010, 03:15 PM
0/11 sssss8594
Feedback Score: 55 reviews
Default if this is the case, why do my lights dim??
http://www.youtube.com/watch?v=H5MP5F-uJAw
between 2:30 and 3:40, i followed his math to figure out what i NEED...if i did the math correct, it would show that my alternator is EXACTLY what i needed to support my battery and amp...it came out to a required 0ah...i must have done something wrong or im missing something...ive got a 1200w amp...brand new diehard battery...220a h/o alt...maybe someone can explain why my lights still dim??...ooo, and im doing my Big 3 this weekend...i dont feel as tho not having done the Big 3 would be this reason, if all my math was correct...am i wrong??
Enclosures
Old 02-18-2010, 03:50 PM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
i know alot of stock alts that support a bat and a 1200w amp. i know my volvo kept 13v and above stock with a hc600 in the back on 1600 watts. sounds like there is something else wrong man. i have no clue but it just doesnt sound right. maybe you should go to advance and put ur batt on the test. it'll also test ur alt and ur car with/without strain. it's free and takes like 5 min if that.
Old 02-18-2010, 03:52 PM
0/11 sssss8594
could it be a badd ground??...the lights only flicker when i turn it up
Enclosures
Old 02-18-2010, 03:53 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
big 3 helps a ton. and u must have something wrong
1999 Durango 2 Memphis Mojo 15's Audiopipe ap3k
4 Date Safe 75 ah batts Alpine hu. Lots of wangin
Old 02-18-2010, 03:54 PM
0/11 sssss8594
Enclosures
Old 02-18-2010, 03:59 PM
Slammintriple6's Avatar
0/11 ssssss594
Do you have the chart that tells you how many amps your alt puts out at said rpms you might need a smaller belt and pulley.Like others said big 3 helps alot
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
either than or... bad bat... bad alty... ect.
you probably wont like me
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
check all your wiring. Double check your wiring. Then get a dmm and test you batts voltage. The die hard batt is just a up front batt correct? I say you need another batt in the rear to stop this. I have 2 100ah each batts on my 2000d and no dimming
Old 02-18-2010, 04:05 PM
0/11 sssss8594
alt only a few months old...it does 220a at i believe it was 1400rpm...mayb 1200rpm
Enclosures
0/11 sssss8594
ya, next paycheck im gettin an xs battery
Enclosures
[SOLD]I-Phone Case andrewtexas123 Miscellaneous Stuff For Sale 5 01-10-2010 03:11 PM
Help me choose a computer case HiloDB1 Technology & Computer 20 09-10-2009 08:20 PM
250 amp and 300 amp GM large case units MECHMAN Wiring, Electrical & Other Installation Equipment 1 07-08-2009 12:38 PM
FS: RAM, RC Truck, PC Case Cage Miscellaneous Stuff For Sale 2 12-18-2008 12:04 AM
[SOLD] EA 300 amp alt big case GM with ext. Reg. bumpin buick Wiring, Electrical & Other Installation Equipment 12 09-03-2008 10:23 PM
