output matching problem?? - Car Audio Classifieds!
Old 02-19-2010, 01:10 PM
coefamily's Avatar
0/11 ssssss336
Default output matching problem??
Im banging my head against the wall here guys, so any ideas would be helpful.
Running aPioneer head unit (dont remember the model) to an MMatts 2000.05 to 3 cerwin 15" wired to a .05 load.
The input range for the amp is up to 2.5 volts. my headunit's output is 6v.
The amp goes into protect mode when we really push it hard.
Ive checked, and rechecked all the wiring, everything is clean.
Could the head be overdriving the amp, putting it into protect?
Old 02-19-2010, 01:13 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Try lowering the gain until you can get the amp to stop shutting down.
My Car, My Ears.
Old 02-19-2010, 01:14 PM
Enellz's Avatar
0/11 ssssss161
Get a tiny run off speaker cable And rumor from you postive input on the amp to the remote input and see if it comes on then...if so it's your head unit
2003 CHEVY TRAILBLAZER
AKA The Batmobile
Pioneer 6000UB
Sundown 3000D
15" DC LVL 4 XL
40' of 1/0 Gauge
A 34 HZ Box
KICK ASS!
Old 02-19-2010, 01:21 PM
fosg8freak's Avatar
0/11 sssss1113
lol your gain is absolutely as low as it can go right?
coefamily's Avatar
0/11 ssssss336
Never heard of that trick before, what will this show?
Old 02-19-2010, 01:22 PM
coefamily's Avatar
0/11 ssssss336
ive tried the gain settings all over the place, but yes the gain is all off
fosg8freak's Avatar
0/11 sssss1113
and even if you cant set the gain low enough to match, it still shouldnt cause a problem. Because it's based on the volume knob of your headunit. Your amp should reach it's limit way before your speakers do.. if you turn it up any farther you're gonna damage something. Thats the only prob of having the gain too high.
nismos14's Avatar
Super Moderators
0/11 ssss18247
I wouldn't use that method, I would ONLY do that if you are thinking the remote output of the hu is bad, which i don't think it is since your amp does turn on.
Your amp is probably going into protect from too much input voltage or heat.
My Car, My Ears.
Old 02-19-2010, 01:24 PM
fosg8freak's Avatar
0/11 sssss1113
if the headunit has a "subwoofer output" control, you can try turning that down so that the h/u doesnt send such a strong signal to the amp.
I have a feeling though that your electrical is not up to par enough for a half ohm load, or your amp is not stable to that ohm load.
Old 02-19-2010, 01:32 PM
coefamily's Avatar
0/11 ssssss336
Im using 0 g throughout. a 160 amp alt. and yes the 2000.05 is half ohm stable. (its in the model name after all) besides, even with anemic wiring, this amp shouldnt go into protect.
has any one used attenuators?
Parts-Express.com:Harrison Labs 6 dB RCA Line Level Attenuator Pair | receivers receiver rca PA line level ir receiver ir ev control attenuators attenuator amplifiers amplifier air
WTB: Matching 2/4 and Mono amps $400 alex5857 Wanting to Buy (WTB) 14 02-19-2010 08:46 PM
WTB (2) matching 8" subs tahoebrotha Wanting to Buy (WTB) 6 01-05-2010 03:10 PM
2 HUs, preferably matching. djman37 Wanting to Buy (WTB) 2 10-30-2009 03:33 PM
I bought a new toy!! TC9 and matching PR orangelss General Car Audio Discussion & Questions 2 10-29-2009 09:43 PM
directed 1100d with a matching 4 channel psychoacoustics Car Audio Packages 0 02-26-2009 11:38 AM
