burnt fuse? - Car Audio Classifieds!
Old 02-19-2010, 05:32 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
Default burnt fuse?
today I was bumping and smelled something bad and thought I was maybe pushing my sub too hard. Popped the trunk and saw that my 150A fuse was burnt but everything was still working? The tip of the fuse burnt and melted the little square block you screw it onto. I swapped out the fuse holder and fuse but what could have cause this to happen?
Old 02-19-2010, 05:37 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Maybe it was a little loose and was moving a bit? (causing a little arching)
Louder. Lower.
Team Tupperware
gbo559's Avatar
Veteran Member
0/11 sssss4814
nah I'm sure it was pretty tightly screwed in
Old 02-19-2010, 05:42 PM
1/11 ssss31258
maybe you need to sand the surfaces of the fuse and the block. It sounds like your fuse was not making full connection. I think the tip that melted was the only part making connection. (on that end of the fuse)
Old 02-19-2010, 05:43 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
but it's been fine like this for 5 months lol it just happened today
Old 02-19-2010, 05:45 PM
Jh8909's Avatar
NJ Car Audio
0/11 sssss3219
Feedback Score: 38 reviews
electronics are weird. they don't have to make sense. but a bad connection could make alot of sense with that kind of thing. sanding will help.
Pics too big in sig.. Please resize
Old 02-19-2010, 08:04 PM
hifonicsviii's Avatar
Loyal Member
0/11 sssss1423
Sounds like it was loose, or not tight lol......
DOn't mater if the amp worked many months down teh road, things rattle loose with base and road vibrations....
556 positive feedback from 506 users on Ebay!!!
Paypal verified ..207..since 2004
Bought from- - ShiZZZoN - pieper88 -
Sold to - super_duper - lilkman2202
Old 02-19-2010, 08:37 PM
kn0wledge000's Avatar
SCCAD POWER SELLER
0/11 sssss3874
Feedback Score: 61 reviews
also dont forget. what amp or amps do you have on this line? is 150 amp strong enough? just a tiny thought
Old 02-19-2010, 08:50 PM
0/11 sssss3164
was it hot out? maybe the heat pushed it to melt. if the wire was hot as well maybe your amp was pulling more current than that fuse could handle? idk it doesnt make sense that it would do it all the sudden. not trying to say it was any of what i said but when its hot outside like 90's i know ish tends to melt and smoke... maybe try running another run of wire no? i wonder if your wire was hot to? maybe the wire was tougher than the fuse?
Old 02-19-2010, 09:39 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
wire was cool, it was like 70 outside, I think it might have gotten loose due to the bass, and 150A is more than enough, I'm running less than 1500rms
Just Burnt My Finger Boomboy Off Topic Chat 40 02-11-2010 10:52 PM
Is my coil burnt? Ronin General Car Audio Discussion & Questions 10 09-08-2009 05:58 PM
[SOLD] KnuKonceptz In-Line Waterproof ANL Fuse Holder w/ Fuse SPY Wiring, Electrical & Other Installation Equipment 5 06-04-2009 02:51 PM
My Car is Burnt :( aturcotte127317 Off Topic Chat 23 05-07-2009 05:08 PM
[SOLD] 1/0 Fuse Holder, Fuse, 4 gauge wire, GM sideposts NoPh33rRaCiNg Wiring, Electrical & Other Installation Equipment 3 02-01-2009 11:14 AM
