if i ground my battery - Car Audio Classifieds!
Old 02-21-2010, 09:06 PM
0/11 sssssss34
Default if i ground my battery
i already made my hole in my trunk so i can ground my battery to my frame... my question is will it be a problem if water touches where im gonna ground to the frame since im doing it under my car?
Old 02-21-2010, 09:11 PM
TNJ
0/11 sssss7882
the engine and battery up front is grounded to the same frame that your grounding it to. i i take my truck off roading and get swamped with mud and water and never had an issue. shouldnt be any problem at all.
No, I'm not dead
0/11 sssss8128
Clean the area where the ground attaches of any paint/mud/undercoating and after you've bolted it down shoot it with some primer followed by paint to seal it from rust.
Old 02-21-2010, 09:28 PM
0/11 sssss1560
Its when water touches both GND and B+ that you have issues
Should I Ground my HO ALT? SacTownBully84 General Car Audio Discussion & Questions 6 02-08-2010 07:35 PM
amp ground to batt neg? michael707 General Car Audio Discussion & Questions 18 02-03-2010 01:24 PM
Amp Ground DeltaOn4's General Car Audio Discussion & Questions 12 10-13-2009 07:09 PM
cap ground ok?? HELP PLEASE bran_luciano General Car Audio Discussion & Questions 12 08-08-2009 09:53 PM
opinions on running power and ground off battery Patrick Simmons General Car Audio Discussion & Questions 18 06-04-2009 04:59 PM
