vinyl or carpeting? - Car Audio Classifieds!
Old 02-21-2010, 10:26 PM
TNJ
0/11 sssss7882
Default vinyl or carpeting?
whats the easiest material to wrap a square box with? vinyl or carpet?
i want something easy to wrap my box in. the vinyl looks clean but carpeting might match interior better.
Old 02-21-2010, 10:30 PM
0/11 sssss2011
Feedback Score: 61 reviews
if you haven't done this before, it's a task to hide the seams for vinyl unless your box has a tuck area. I personally like suede as a cheaper suede cost the same as a good vinyl but carpet if by far the easiest to wrap with.
Old 02-21-2010, 10:33 PM
TNJ
0/11 sssss7882
ive wrapped before. the sides of the box are pressed tightly up against the sides of the trunk. its the entire width of the truck. so they sides will no be seen at all. or the bottom obviously. just the one side facing out the back doors of a tahoe and the top. nothing else.
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
carpet is easier to stretch IMO and will look nicer with less work involved, you can get a nicer look with vinyl but it's hard to stretch it without leaving wrinkles.
gbo559's Avatar
Veteran Member
0/11 sssss4814
then go with vinyl
Old 02-21-2010, 10:35 PM
TNJ
0/11 sssss7882
Originally Posted by gboo559 View Post
then go with vinyl
the sides will have faceplates covering them and be wrapped in vinyl as well. so i have alot of areas to hide errors.
Old 02-21-2010, 10:49 PM
Vaginatarian's Avatar
0/11 ssssss473
Sounds like you already want vinyl anyways
If you dont see the left and right sides, laying a long piece of vinyl over the front\top\back seems pretty simple and trouble free
Old 02-22-2010, 06:26 AM
TNJ
0/11 sssss7882
i really dont care, i just want something simple to do.
CACO vinyl?? kn0wledge000 Team CACO 7 02-24-2010 07:36 PM
Tan Metra Vinyl scottiej Wiring, Electrical & Other Installation Equipment 8 11-17-2009 10:47 PM
carpeting a box gbo559 Sound Deadening & Fabrication 7 11-03-2009 12:51 PM
carpeting waresgaragestereo General Car Audio Discussion & Questions 4 06-18-2009 08:38 PM
[COMPLEX] Carpeting/Box Build Technique danteBirosel Tutorials & Quick References 1 11-12-2008 02:44 PM
