Question on wiring sub unorthodox. - Car Audio Classifieds!
Old 02-22-2010, 10:17 PM
0/11 sssss6061
Default Question on wiring sub unorthodox.
Ok, I was planning to use an mb quart DSC4125 for my siters system. I would run the comps on the front channels, and then run the single sub bridged on the rear channel. Well, I messed up. I was thinking it was 500x1 @2 ohm when bridging the rear channel. It is actually 4 ohm. Here is what I was thinking. I could just run each side of the sub on it's own channel... That way each side would be getting 125rms, because the sub is dual 4 ohm. Anyone know what I'm saying? I mean they both run off the sam gain/settings, so it would be ok right?
edit: I guess it would actually only be 125 rms per side. I'm really failing at this...
Old 02-22-2010, 10:24 PM
No, I'm not dead
0/11 sssss8128
If you run each VC to it's own channel you'll be seeing 125WPC not 250. The sub is D4, the DSC4125 does 125W X 4 into 4 ohms...
That said it'll be fine to run it the way you're thinking.
Old 02-22-2010, 10:28 PM
0/11 sssss6061
Ok, I thought it would be ok like that. Thanks.
Odd wiring question grimreper912003 General Car Audio Discussion & Questions 6 12-11-2009 10:02 PM
wiring question blazron22z General Car Audio Discussion & Questions 4 11-07-2009 07:24 AM
Sub Box Wiring Question 92K1500 General Car Audio Discussion & Questions 17 07-07-2009 08:31 PM
Wiring question! bnasty General Car Audio Discussion & Questions 18 06-17-2009 12:15 AM
wiring question? Biggy General Car Audio Discussion & Questions 11 06-04-2009 11:12 AM
