why is it? - Car Audio Classifieds!
Old 02-23-2010, 04:28 PM
TNJ
0/11 sssss7882
Default why is it?
i have 4 xtant x1001 amps. here are the specs:
http://www.xtant.com/archives/html/t...s/X1001man.pdf
1x500 @ 4 ohms
1x1000 @ 2 ohms
1x1000 @ 1 ohm
why will it only stay at 1000 watts at 1 ohm? is it a 2 ohm stable amp? this just came to my mind and stumped me. if i have 1 memphis m3 mojo d2 to each amp they will see 1000 watts correct with a 1 ohm load?
Old 02-23-2010, 04:33 PM
Man Behind the Curtain
0/11 sssss1699
correct, it doesn't gain any power under 2ohm because of the way they did the power supply in the amp.. There are a few amps out there that are like this.
Old 02-23-2010, 04:36 PM
TNJ
0/11 sssss7882
and of course i have 4 of them. lol. so if i had 2 d2's wired to 1 amp parallel that would be a .25 ohm load?
why would they do this? im not complaining, the mojos only take 1500 rms and people say the xtants are under rated so its fine by me.
0/11 sssss4714
This and its nice in some cases as well, you can change subs but have a amp that is very versatile!!
TEAM GORILLA
TEAM GHOST MOB
2007 Ford F150
1995 T-Bird P.I. 4.6L 312rwhp-Comp car,work car
Trunk Car class for 2011 MidwestSPL division!!
Old 02-23-2010, 04:40 PM
0/11 sssss1699
no 2 d2s all parallel is 0.5 Why you want that? Run each sub in series then parallel both subs for 2ohm. Thought you had 4 subs and 4 amps?
Old 02-23-2010, 04:43 PM
0/11 sssss1699
Nice some times..Companies also setup the amps to do less power at 1ohm then say 2ohm. Phoenix Gold used to do that alot. Also can be cheaper to build the amp this way. Don't need over sized parts to carry the current load.. Can run higher rail voltages at higher loads for good power.
Old 02-23-2010, 04:46 PM
TNJ
0/11 sssss7882
just curious. i plan on running one to each. thats why i have them. i was just doing some research on my equipment. it seemed odd to me that they were the same power at 2 ohms as at 1 ohm.
Old 02-24-2010, 08:35 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Look at the JL's they do the same power from 1.5 ohm to 4 ohms, very regulated power supplies.
My Car, My Ears.
Old 02-24-2010, 08:55 AM
TurdFergueson2's Avatar
0/11 sssss3902
Not 1 ohm stable, but the Alpine PDX series amps were the same at 2 and 4.
