WIring Question - Car Audio Classifieds!
Old 02-23-2010, 10:04 PM
sk8infreak1's Avatar
Sir Strickland
0/11 ssssss200
Default WIring Question
im running 2 batteries in the back of my car
i want to know if i need an inline fuse for both 1/0 lines coming from the front battery to the rear 2
or
do i need the inline fuse in between the amps and the batteries
Bought From: Profundus-sanus, goodstuff,
Sold To: Lax 916
Old 02-23-2010, 10:05 PM
TNJ
0/11 sssss7882
no inline fuse between the front battery and the rear ones and inline fuses in between the rear batts and the amps
Old 02-23-2010, 10:12 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
Yes, I'd fuse all of the positive wires minimum 2 feet from each bank of batteries. That way, if ANYTHING happens to the wires, you blow a fuse instead of a battery. you dont really need a fuse from the battery to amp, because if you have a fuse on the other side of the battery, that will pop if anything happens.
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 02-23-2010, 10:14 PM
TNJ
0/11 sssss7882
so im wrong? or is either way acceptable?
Old 02-23-2010, 10:18 PM
Sir Strickland
0/11 ssssss200
so wait
f is fuse
o is battery
o--f----------------f--front battery
o--f----------------f-front battery
none between the amps n batteries?
Sold To: Lax 916
Old 02-23-2010, 10:22 PM
TNJ
0/11 sssss7882
by the way he described it that looks right.
Old 02-23-2010, 10:24 PM
Sir Strickland
0/11 ssssss200
i have 2 back batteries tho
Sold To: Lax 916
Old 02-23-2010, 10:26 PM
TNJ
0/11 sssss7882
i have 2 yellowtops in the back of my truck and run straight 1/0 gauge to the rear 2 and have a fuse from the battery to the amp and havent had a problem with it in 3 yrs.
Old 02-23-2010, 10:28 PM
sound_around's Avatar
0/11 sssss9691
Whats a fuse
Old 02-23-2010, 10:30 PM
Sir Strickland
0/11 ssssss200
jeeze what kinda amp you got that needs 3 optimas?
ok that sounds good.
one more thing though.
should i run each amp off of 1 battery or both amps off with with a distributor
or does it even matter
Sold To: Lax 916
Odd wiring question grimreper912003 General Car Audio Discussion & Questions 6 12-11-2009 10:02 PM
wiring question blazron22z General Car Audio Discussion & Questions 4 11-07-2009 07:24 AM
Sub Box Wiring Question 92K1500 General Car Audio Discussion & Questions 17 07-07-2009 08:31 PM
Wiring question! bnasty General Car Audio Discussion & Questions 18 06-17-2009 12:15 AM
Sub Wiring Question Again worstenemy453 General Car Audio Discussion & Questions 22 12-07-2008 08:40 PM
