Using computer case fans in car audio - Car Audio Classifieds!
Old 02-24-2010, 03:35 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
Default Using computer case fans in car audio
Just wondering if anyone uses computer case fans in amp rack builds. I wanted to use (6) 80mm fans. Just wondering how you wired them. The fans I wanted to use are (4) pin 12 volts fans.
http://www.newegg.com/Product/Product.aspx...N82E16811998109
I figure I would cut off the adapter thing. Would you hook it up like you would a HU? Yellow/red to power/constant, black to ground?
Old 02-24-2010, 03:53 AM
No, I'm not dead
0/11 sssss8128
That's not an adapter ring, that's the frame. You'd hook a relay inline to the remote (as a trigger) on one leg of the coil, the other leg of the coil to ground and hook the power for the switched leads to the amp's 12V line and hook the fans red wires to the normally open switch pole. The fan grounds would need to be hooked to chassis ground. Cut the two thin wires on the fan from the pass thru, red is power (+) and black is ground.
Personally I'd go with 120's if you have the room. a 120mm can move as much air as 3 - 80mm units and produce less noise.
Old 02-24-2010, 06:32 AM
skmfkr's Avatar
0/11 ssssss791
ive got some scythe slipstream 120mm fans in my computer that were like $17-18 for two and they move a combined 220cF min. that would be cheaper and move more air than 6 of those. altho they might be louder. they are 37dba compared to 25dba for ur linked fans
2012 Hyundai Elantra Limited
2 15" DC XL's + RD D9
AQ4X90 + 15 IA DP 4 sale
Old 02-24-2010, 01:06 PM
No, I'm not dead
0/11 sssss8128
You can run 2 of these with one on each side of an enclosed amp rack and have 27db of added sound with 72CFM of balanced airflow. Is the rack going to be enclosed?
Old 02-24-2010, 01:18 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
What about cross flow fans?
Team CACO Team SHOK
Supporting Member
Old 02-24-2010, 01:23 PM
No, I'm not dead
0/11 sssss8128
They work good in size limited applications but they're more expensive than an axial flow fan.
Help me choose a computer case HiloDB1 Technology & Computer 20 09-10-2009 08:20 PM
How loud are computer fans? vellocet General Car Audio Discussion & Questions 16 07-24-2009 12:50 PM
hey car audio fans what up emmer06 New Member Orientation 21 05-18-2009 09:37 PM
Empty computer case nitro_freak1 Miscellaneous Stuff For Sale 1 12-09-2008 10:29 PM
[SOLD] Computer Fans RidnClean Miscellaneous Stuff For Sale 8 11-04-2008 04:48 PM
